1 - 20 of 68 Posts
I'm starting to wonder if this kit from "Rock Equipment" wouldn't work. It looks like you can order just the plates and then source your own u-bolts. It looks like the bottom plate would protect the center pin to some degree.
http://www.rock-equipment.com/
OK4WD sells these and it says they will work on Dana 44/60 w/ 2-2.5 inch leafs...
http://www.ok4wd.com/index.php/catalog/product/rock_equipment_u_bolt_flip_kit/
And a photo from OK4WD
http://www.ok4wd.com/index.php/product/image/865/
***EDIT: Installed on 11/9/07***
Alright... here's a quick shot of the stock set-up for comparision (w/ longer u-bolts for my Alcans);
And... afterwards;
I have to say that this kit went on fairly easy. The top plates cleared the ABS line brackets without any problems. I ordered custom 9/16 square end u-bolts that were 8.5 inches long. Could have gotten away with 8 inches.
I only really gained about an 1/8 of an inch of ground clearance, according to my measurements. I guess the biggest added benefit is the approach and departure angles, so-to-speak, of the bottom plate.
I had originally hoped that the top plate might work for an air bump striker plate, but the distance between the nuts doesn't really give you a lot of room for error.
If you want to try that out on my truck to make sure it works before you put it on yours you can do that!!! LOL
I donno, you never really know till you get the stuff in your hands and try it yourself I say go for it. If it doesnt work there is always ebay.
Alright... I ordered the kit (minus u-bolts). I'm pretty sure I can make it work. The only thing that might get in the way is the stupid ABS wire brackets on the front of the axle tubes near the u-bolts on each side. I'm hoping I don't have to modify or grind those off.
I have hopes that when it's all said and done, I might be able to find a way to use those brackets as air bump striker plates for the rear (yeah I said it... air bumps). We'll see how it goes. If I can do it, that might help justify the $139 price tag...
:scratch:
Discussion Starter #7
willgr1 said:
updates??
Expected the kit to arrive on Friday or Saturday. It didn't. Called OK4WD this morning. They said it didn't ship out due to a "miscommunication" with their warehouse. They said it would go out today, next day air for no extra charge.
Still have to find some u-bolts too. The selection at the local auto parts stores is pretty poor. Going to have to order them.
OregonX said:
willgr1 said:
updates??
Find a local spring shop in the yellow pages.. they will more than likely have them in stock.
Yeah, local spring shop. And if they don't have them in stock, they will most likely make them for you while you wait.
They are special u-bolts in that they are square instead of round. He might be able to get them, but I doubt he has them laying around.
You know, you might be right. I am not sure how the Frontier u-bolts are setup, but I wouldn't be surprised if they were normal U-bolts with the plate on top of the spring (basically take out setup and flip it over for the spring over).
Well I dont know about the titans but I know for a fact that the fronty Ubolts are square because when i ordered my calmini lift kit, I ordered the frontier kit... and guess what type of Ubolts came with it...
Too bad I already sold them or I would just ship them over to Shawn right now. :cussing:
Ahh, well then...
Frontier u-bolts will work with a flip kit then.
This also means that Calmini would have them as well.
I ordered the parts for a flip kit from ruffstuff. There stuff is much beefier than rocks. When I get it I'll post a couple pics. (it'll be a couple weeks, because I ordered something custom from them as well and they are going to ship it all at once)
Discussion Starter #19
Well, the UPS guy just pounded on my door while I was getting ready for work. They finally arrived.
I will say I don't have any concerns about these not being "beefy" enough. They're made from 1/2" steel plate. And I think they're going to *barely* clear those ABS line brackets. Keep your fingers crossed.
EDIT: I found a local brake & alignment shop that also re-arches spring packs and makes custom u-bolts. I'll go in there in the next few days and hopefully have this stuff on by the weekend. Stay tuned...
That is nice that the plates are 1/2" thick, That is actually thicker than the ones I ordered. I thought they used 3/8". What diameter are the U-bolts? 9/16 or 5/8? The ones I got are 5/8", but most I have seen are only 9/16"
1 - 20 of 68 Posts
