1 - 5 of 5 Posts
For some reason, my X will not start up. I just got a new battery a few weeks ago, so that's not the issue. I even tried to jump it off from my friend's Tahoe several times. It's like it tries to turn over for a split second and then just starts clicking over and over. Has anybody ever had this happen and what do you think it could be? Maybe a bad connection somewhere or the starter? I guess I'm going to have to get it towed tomorrow...
I have, it turned out I had a corroded connection at the battery terminal. I got away with whacking it a couple times whenever it wouldn't start with a wrench, pretty ghetto, but it worked. Or maybe you loosened the connection when you changed it and need to retighten
It was a loose connection from the negative port. Tightened her up and its good to go.
1 - 5 of 5 Posts
