1 - 20 of 183 Posts
Intro Photo:
Username: Trixter404
Year: 2011
Color: Night Armor
MODIFICATIONS
Suspension, Lift and Tires:
Nisstec 1" Lift Top Plate Spacer (9/18/15)
Radflo 2.0 Extended Travel Adjustable Coilovers w/ 650 lb. Springs (8/18)
SPC Extended Travel UCA's (coil buckets modified) (9/15)
SPC Upgraded Upper Ball Joint Kit (8/18)
Moog LCA's (8/18)
Nisstec Adjustable Rear Shackles (9/15)
Bilstein 5125 Series Extended Travel Rear Shocks (2"-2.5" lift) (9/15)
Rugged Rocks Offroad Deaver 4-Leaf Add-a-Leaf (5/18)
RideEffex Helper Springs (AutoZone) (4/21)
PRG Cam Bolts (8/13)
Goodyear Wrangler Duratracs 285/75/16 x6 (4/18) (2nd set - almost 78k on 1st set)
Matching Spare Wheel & Tire
Second Spare on Stock Steelie
SpiderTrax 1.5" Hub Centric Wheel Spacers x4 (10/16)
Front Sway Bar removed (10/16)
Rear Sway Bar removed (8/13)
Engine/Drivetrain/Performance:
Volant 12740 Cold Air Intake (2/18)
Airflow Snorkel (4/16) (Offroad Gorilla group buy)
eBay Snorkel Head (11/17)
AEM Dryflow Air Filter (3/18)
Borla 40348 ProXS Muffler (7/18)
Rear Diff. Breather Extension (4/16)
No-Spill Systems Oil Drain Plug & Tubes (12/16)
My Lead Foot
Hefty Fabworks Front Winch Bumper (4/16)
Max-Gear Armor (Maxterra) Rear Bumper w/ Tire Carrier & Jerry Can Holder (11/16)
Hefty Fabworks Skids (7/15 )
• Radiator
• Engine
• Transmission
• Transfer Case
• Fuel Tank
White Knuckle Sliders (1/5/14)
Ballistic Fabrication Rear Differential Cover (4/16) (purchased from jeffnjm3)
Gobi Passenger Side Ladder (5/15) (group buy)
Gobi Tailgate Gas Struts (5/15) (group buy)
Offroad Gorilla Hood Gas Strut Kit (7/15) (group buy)
Nissan Side Window Deflectors (5/16)
AM Fabrication Low Profile Roof Rack (seasonal)
Freespirit Recreation Odyssey Hardshell RTT
Yakima RidgeBack 4-bike Hitch Rack (seasonal)
Yakima Big PowderHound (seasonal)
OEM Crossbars added (purchased from jboy)
iJDMTOY Black Front Bumper License Plate Re-locator Bracket
"Stealthed" '05-'08 Grille (5/16)
Shadow Chrome Black Grill Emblem (7/16)
Splash Guards removed (6/13)
Melt Mod (8/3/13)
Bosch ICON Wiper Blades
Electrical & Lighting:
Odyssey Extreme 35-PC1400T Battery (4/18)
Rockford Fosgate Positive Battery Terminal (4/18)
HID Projector Retrofit (4/16)
• Kensun HID 35w Headlight Conversion Kit
• Nilight 2.5" Mini HID Bi-Xenon Projector Lens/Shroud x2
• Kensun HID H1 Bulbs - 5000k
DNA Motoring LED Fog Lights - 3000k (9/17)
Easy Fog Light Bypass (4/16)
OEM Fog Light Switch added (6/13)
Philips Vision 921 LED Backup Lights - 6000k (10/15)
Philips Vision 3157 LED Tail Lights - Red (11/15)
Philips Vision 3157 LED Rear Turn Signals - Red (11/15)
Diode Dynamics HP48 3157 LED Front Turn Signals - Amber (12/15)
Aaron 50W 6ohm Load Resistors x4 (2 ea. connected in parallel at rear - 11/15)
Diode Dynamics HP3 LED Front Side Markers - Amber (3/16)
Diode Dynamics SMF6 Dome/Map/Trunk LED Lights (5/17)
OEM 7-pin Tow Harness added (6/13)
Uniden PRO520XL CB Radio (11/24/13)
Astatic 302-636L Noise Cancelling CB Microphone (8/14)
FireStik FireFly 3' Tunable Tip CB Antenna
FireStik SS-3H HD Antenna Spring (11/29/13)
FireStik SS-184A Antenna Mount (5/17)
Switch-Pro SP-8100 (7/17)
Rigidhorse 42" Single Row LED Flood/Spot Combo Light Bar (2/21)
Offroad Gorilla Dual Light Bar Roof Mounts (3/15)
MicTuning 22" Amber/White Dual Function LED Light Bar (2/18)
LED Kingdom 4" LED Cubes x2 (rear) (11/17)
IF Rear Xterra Light Bar Mount (11/17) (Not sure that I like it)
LED Kingdom 4" LED Cubes x2 (ditch lights) (4/21)
Kevariy Stainless Steel Universal Adjustable LED Mounting Bracket x2 (4/21)
Interior & Electronics:
Pioneer FH-X700BT Stereo (3/13)
Garmin Nuvi 50LM GPS
Samsung Galaxy Tab S2 8" Tablet w/ Backcountry Navigator Topo GPS app
Excelvan Car Floor Seat Bolt Mount Tablet Holder Stand
Coverking Neoprene Front Seat Covers - Black (12/17)
WeatherTech DigitalFit FloorLiner (front only) (10/28/13)
Nissan All Weather Floor Mat (rear seats only) (5/17)
Auto-dimming Rear View Mirror w/ Compass (8/17)(thank you Snowtrout)
BESTEK Dual 110V AC Outlet and Dual USB 3.1A 300w Power Inverter (3/14)
Utili-track Cleats Substitute
Rear Cargo Cover (thank you AustinFound)
Recovery & Trail Gear:
Engo E10000S Winch (4/16)
Factor 55 ProLink (4/16)
CSI D-Ring Recovery Hitch
ARB Recovery Gear Bag
ARB 4" x 30' Recovery Strap
Smittybilt 3" x 30' Recovery Strap
• Driver 3" x 10' Tree Saver Strap
Smittybilt D-Ring Shackles
• Smittybilt Snatch Block
ARB E-Z Deflator
TRED Pro Total Recovery & Extraction Boards x2 (via KickStarter)
48" Hi-Lift Jack
Hi-Lift Jack 2" Tube Mounts
VIAIR 400P-Automatic Air Compressor
Amflo 25' 120psi Hose & Campbell Hausfeld MP6000 Tire Inflator w/Gauge (backup)
Boulder Tools Tire Puncture Repair Kit
Trasharoo (ExPo group buy)
8-Gallon Rubbermaid ActionPackers x3
5-Gallon Fuel Jerry Cans x2
5-Gallon Water Container
Ordered/Purchased/Not Yet Installed:
Blue Sea Systems 12-Circuit Fuse Block
upTOP Overland Roof Rack
What's Next?
OBA
Air Locker(s)
Maintenance
Fluids:
• Front/Rear Differentials - Mobil 1 75w90 Synthetic Gear Lube LS (@118k)
• Transfer Case - Nissan Matic D ATF (@118k)
• Engine - Castrol EDGE Extended Performance 5W-30 Advanced Full Synthetic (@149.5k)
Service:
• Transmission (@107k)
• Brake Fluid (@107k)
• Radiator (@107k)
• Spark Plugs (@107k)
PHOTOGRAPHS
Stock (March 2013 - still on the lot)
Now-ish (November 2016)
1 - 20 of 183 Posts
