Transmission Leak. . .
199 Views 3 Replies 3 Participants Last post by  Jgrossi
3
Hello everyone,
I was having a look under my 2010 automatic xterra off road today and noticed some leakage/seepage happening around the main seal. Is this something to be concerned about or just something to keep an eye on? Fluid level is good and no drips on the ground
Thanks
1 - 4 of 4 Posts
I'm told a rear main seal replacement is not the easiest of jobs.
I would probably try to degrease everything and confirm where the leak originates from
Check your valve covers. 99 times out of 100, the rear main seal is going to leak from the bottom half
  • Like
Reactions: 1
Checked the valve covers and it does appear to be some oil residue around the gasket. Thanks for the tip i will start there and see how that goes!
1 - 4 of 4 Posts
