1 - 12 of 12 Posts
Hey everyone, recently did a drain and fill on my auto '10 SE, 161k miles. I only drained the pan from the bolt and refilled from the dipstick hole. I'm a little confused though as I drained 4000mL of fluid, and I added back 4000mL (4, 1qt bottles of matic s fluid) or therabout, plus a little extra (barely 250mL) for spillage I caused. I checked the dipstick and it is above the hot mark now. I let the car sit over a few days so I knew it was cold, checked again and it's still reading on the hot line. I figured a few days would be long enough to allow all fluid to seep down the dipstick hole but it's still reading too high. I've driven the car at least 30 miles to test it out and no issues. No slamming, hesitation, leaks, everything seems fine. Am I missing something here? I've checked the fluid at least 4 times at different temperatures and the dipstick is always high, regardless of temp. Obviously I'm cleaning it off before checking, so what the heck is going on?
Thanks anyone who may know what's up.
Werks
Werks
Are you checking your level with the X running and in Park? You MUST check your ATF levels with the vehicle running or it will read incorrectly.
Two tips.
1. Check your transmission fluid with your vehicle running , warmed up and in park.
2. I've read the service manuat indicates after removing the bolt, check the fluid with the dipstick tab turned 180 degrees from its original position and depressed fully
Registered - From Westminster, CA, USA
Yea definitely turn the dipstick 180 degrees when putting it back to check the fluid level. If you don’t it’ll read incorrectly high every time
I did a poor man's flush earlier this year and sympathize with AutoWerk's question. I find it hard to read the AT fluid dip stick. I have checked it (while running) both cold and 'hot' or what I believe is hot and concluded it is OK.
Question: Is slightly overfilling the transmission fluid a bad idea?
I know that overfilling the motor oil is a really bad idea.
  • Like
Reactions: AutoWerks
Two tips.
1. I feel dumb. It didn't occur to me if I tried with the x running or not. Most likely not though. D'oh! I'll check again now that it's been cold for a few days and I'll turn it on.
2. I was doing the little twist to get the dipstick seated properly, this led me to believe it was causing the improper reading as it seemed it was going further down the tube. So I will do this when I check it again.
Thank you
Alright, I turned the car over, checked the dipstick and its sitting right at the top of the cold notch. I of course didn't take a picture of it before but remember it being around the same spot as well. Que sigh of relief. I'll need to read through my haynes manual but I don't recall it saying to check while the car is running. Its the little things those manuals neglect! Thanks everyone.
Werks
I have been told by a transmission shop that overfilling of a transmission can be just as harmful as over filling an engine.
Doing such can:
Increase fluid pressure
Cause foam in the fluid which can affect lubrication and if friction increases so will heat.
Damage seals
Affect shifting
Thankfully the solution is rather simple.
Loosen the plug and let some out :)
  • Like
Reactions: westslope
Doing such can:
Damage seals
Affect shifting
bla bla bla
bla bla bla
Westslope.
Its clear Tlrtucker has some first hand knowledge to share.
Possibly provided enough time he will do so.
I sympathize with the OP - getting the right fill is a major PIA. Here are my observations / opinions.
The difference between not on the stick at all - and overfull is around 8 oz's at absolute most - so you don't get much wiggle room.
Cold marks and hot marks on the stick do not correlate. If you get it full on cold it will be way overfull at hot. Full at hot will be bairly on the stick at cold?
The proper procedure from the FSM as I recall is to stick the dipstick in its correct position, then rotate it 90 degrees before pulling out.
Based on all this BS I underfill a little on a D&F and add 4 oz's at a time until i get back to the correct level which sometimes takes a bit of trial and error - and I fill it to hot level. I have also read that overfilling your trans can cause aeration of the fluid and also possibly extra pressure on the pump. However I am sure they have designed a small amount of safety factor - meaning over by 4 oz your likely OK. Overfull by a quart maybe could be an issue? Just guessing.
Discussion Starter · #12 ·
Very informative. For anyones future reference, I suppose if I had poured a perfect amount and got every drop out of every bottle, I addedd more than came out. 4000ml drained vs 4300ml added. But, with human error factored in, I feel that came out to about 4000ml. At idle the dipstick was a hair over the cold notch. Which sounds somewhat indicative to what you stated, so hopefully I did my shoddy math correctly haha
If I notice any issues, I'll be sure to update this post.
1 - 12 of 12 Posts
