1 - 1 of 1 Posts
Question on secondary coolers and fans?
Did the by-pass over a week ago - fan, thermo switch, temperature guage and procom fan. Did ok, until I tried to go up a mountain. Sored up to 200+, so I know I need the second cooler which makes sense. Question - has anyone tried placing spacers on the stock cooler to push it forward in order to get the procom fan behind the cooler to act as a pusher, then place the b+m cooler in front of the stock cooler? The applications guide for B+M states that you should also go thru the stock cooler, then into B+M and back to trans. Back in an earlier section, the reverse was suggested, to go thru b+M first, then stock - any comments on this ? Would suspect B+M directions are the way to go. Thoughts? Anyone done this approach?
1 - 1 of 1 Posts
