1 - 20 of 36 Posts
· on line
is that ratio just for the OR?
i just found out that the S has the same rear as the OR minus the locker. please correct me if im wrong. i dont want to be that guy that spreads incorrect info.
· on line
You are correct.
· on line
My thinking is that it should work with ours since we share the same exact t-case. That would help us out even more then the first gen so who's going to be the first one to try?
· on line
Everything I've seen says we have the exact same TX-10 that Gen1 has plus some electronic controls added. Now if only Calmini could get the gears off backorder or does someone know of another place. Muzik I volunteer you to try this one out. :geek:
· on line
I would love to get a look at the gears before actually buying any though. That's a huge chunk of change to plop down if they don't work. If I drop and open the TC I should be able to tell if they "might" work just bu looking at them. I would hate to pull the gears out only to find that they don't fit and then have to find a rebuild kit to put the TC back together.
· on line
I feel your pain there. It's definately not something you want to jump into without a good plan.
· on line
Well there should be plenty of Gen1 and Gen2 together this weekend so we all can look at them in Richmond. I don't think Brent is right on that one but then again I might be wrong to. :geek:
· on line
Discussion Starter · #16 ·
Hope you're right and Brent is wrong, but I guess both T/C options would have claimed they fit 2nd. gen as well.
· on line
Please prove him wrong.
· on line
There's a lot of stuff that he has stated that was incorrect about the '05+. If it's a part number or something out of the owner's manual then it's good for that.
· on line
I'll do that. Also Dan and Dyna know but for everyone else TC gears for sure are coming for us.
1 - 20 of 36 Posts
