I'm sure everyone is bored with this topic but I'm new (Prod39 sent me...). I have an 06 OR that I bought used without a bumper hitch so I would assume it does not have the tow package. I bought a used hitch from Prod39 (thanks again...) and now I need the wiring. Courtesy Nissan (http://www.courtesyparts.com/xterra/N50_towing.html) shows 2 harnesses, a 7 pin for $56 and a 4 pin for $18. I have a 4 pin trailer (and I'm cheap) so I'd like to buy the 4 pin harness but the fine print says it only works with the tow package.
1. Will the 4 pin harness work without the tow package? When I installed the hitch I saw what appears to be the factory connector.
2. If the tow package comes with a 7 pin connector and the 4 pin won't work with out the tow package, why would anyone buy one? The 7 to 4 adapter is cheaper.
3. How can you tell if you have the tow package?
4. Anyone have a link to a wiring diagram?
Thanks in advance...
