Towing Impressions with the Xterra
48971 Views 117 Replies 45 Participants Last post by  Tlrtucker
Towing with the Xterra
I just got back from a trip which involved towing a 6x12 U-Haul weighing about 3500's. While no where close to the tow rating of the X, it gave me a pretty good idea of how the X handles towing.
Here's my impressions:
Power: There's plenty for towing at this weight. On the flats and slight inclines, 6th gear and cruise control worked at speeds up to 75mph.
On larger hills, a downshift to 5th was all that was required. Cruise control would hold up to 75mph with out any problem.
Accelerating up to speed was a snap, especially once the engine was above about 3000 rpm's.
Technically, I could have left it in 5th the entire time, but I wanted a little better mileage.
Mileage at speeds from 65 to 75mph varied from a high of 13.5 to a low of 11.8. This is a 6 speed manual that is just past its break-in period.
Brakes worked well. The U-Haul has hydraulic surge brakes. I didn't test full bore stops, but stopping power seemed adequate.
Handling was good. The very responsive steering of the X requires a bit of getting used to, but it's no different than when it's unloaded. There was no sway evident, except after my first attempt to load the trailer. I had temporarily loaded a Dana 60 and 14 Bolt axle in the back half of the trailer to transport them a short distance before I reloaded the trailer. Once I reloaded the trailer, all was good. Weight distribution ended up being about 70% front and 30% back, so it was a bit front heavy.
Suspension: This is the only thing I can find fault with. The rear of the Xterra sagged more that I would have liked, but this is not unexpected. Overall sag was about 2 at the hitch. It was not on the bump stops and did not bottom out very often. I would run a weight distributing hitch at tongue weights over about 300's but these are not recommended with U-Hauls.
Overall, this is a pretty good little tow vehicle within its limits.
-Old Army
  • Like
Reactions: 1
21 - 40 of 118 Posts
I tow a 6x12 work trailer everyday that weighs anywhere from 3-4K lbs depending on what tools and material are in it.
Only thing I wish I had where a brake controller and trailer brakes. Have neither but do fine, I just maintain my distance on the freeway and don't drive like a prick.
If I were stock suspension i might be singing a different tune but having decent leaf pack makes night and day difference.
I'm towing a 5x10 cargo trailer half way cross country with my 2013 XTerra Pro. I'm concerned about sway in the rear. Not sure if the Pro has more leaf springs in the back than non Pro models. Any suggestions ?
I use this sway control.
https://www.etrailer.com/Weight-Dis...5vgtga-5foQSRcCKA4XFVaaPTFUPfIfBoCdJIQAvD_BwE
You'd also need a plate to mount the front ball to your ball mount. I've got something like this, but not this one in specific.
https://www.etrailer.com/Accessories-and-Parts/Reese/RP26003.html
If you've got too much sag in the rear you can buy an add a leaf economically. I added air bags since I tow often enough to justify the expense.
  • Like
Reactions: 1
I have a MT Pro4x and I tow a 20" boat on a tandem axle trailer with surge brakes. The whole rig, truck, trailer, boat and all the equipment needed to fish tossed in for good measure, tipped the scales at 8,740 lbs (measured at a local landfill scale) truck without boat weighs 4360 for a boat and trailer weight of 4380. So, depending on which vehicle has more gas in it, the boat can outweigh the truck. I also have brand new HD leaf spring packs, add a leaf, HD shocks and coil overs. At highway speeds, the boat can waggle around to the point of being noticeable. the best way to stop the waggle is to accelerate, down shift and hit the gas. Unless you're going down a hill into curve.
In a nutshell Xenawarrior, a Pro4X will tow the 5x10 trailer just fine as long as your not exceeding the 5000lb limit and your doing the speed limit or less(better mileage as well). So, if your pulling normal household stuff, you are unlikely to get close to 5,000lbs. If youre filling it with granite countertops, good luck :)
I have a friction type sway control device. One end mounts to a swivel ball bolted to the side of your trailer tongue. The other end attaches to a swivel ball that is welded to the side of your receiver hitch near the ball. Works great to eliminate any sway.
Most repair shops can do the little bit of welding needed to attach the swivel ball to your hitch.
I have been looking at some Yamaha boats ranging from 19 to 21 feet. The two things I have been considering is if my X will tow it and if it will fit in my current garage. Anyone out thier pulling a SX/AR192 or SX/AR210 with an Xterra?
So to me it seems like the weaklink in Xterra's towing capablities is the length and weight. It has the power, transmission, and brakes of frontier/pathfinder that have a 6500lb vs the 5000lb tow rating.
Correct. The short wheelbase is the main reason for the decreased towing capacity.
  • Like
Reactions: 1
Looks like I will be picking up a Yamaha AR210- It says it is 3000lbs dry. I guess I will find out if my Xterra can tow it or if I will need a tow vehicle on the way home.
I tow a ~3000 lb popup RV, no problem but it has electric brakes.
Looks like his load will be around 4000# with the trailer.
Does it have surge brakes?
What year, trim and transmission are you running? Stock suspension?
Any X can handle the load, its just a matter of attention to detail. The older and less equiped, the slower and more careful you will need to be. make sure your trailer or car hauler is as level as it can be
Trim is 2009 Off-Road with AT. Stock Supension.
I figure I won't use OD and will be looking at airbags for rear. I need to figure out what type of brakes on are the trailer.
That should be easy. If the trailer has a 7 pin connector it should have electric brakes. If it has just a 4 pin connector then it should be surge brakes, especially if there is a surge box on the tongue.
5 pin connector. Surge brakes and a 5th pin is to disable for backing up.
with surge brakes and not using the OD, as long you keep the speed in check, the X will be fine.
Huh. :scratch:
First time I've ever heard of a 5 pin connector. Learned something new today.
Huh. :scratch:
It's pretty common on boats and other trailers that use surge brakes. Need a signal to disable the surge brake so you can back up without locking up the trailer brakes.
  • Like
Reactions: 1
Timbrens Timbrens Timbrens. Seriously. Huge night and day difference on stock suspension.
Can I get an adapter for 5th plug or do I need to get some type of controller?
