81 - 100 of 136 Posts
USER NAME: Jasontamu
DATE SWAPPED: 1/30/16
LINK TO YOUR BUILD THREAD: None
PICTURE AFTER SWAPPED:
So, i was rushing so much after bleeding the brakes with the motive power bleeder that when i went to put the wheels on i forgot to put the rear spacers I purchased on. so mad!.....oh well, ill install them tomorrow and get some better pis on my next outing.
Finally swapped....been wanting to do this for a long time.
-J
PICTURE AFTER SWAPPED: This is the first pic I took after moving it out of the garage, ill update with a better pic later:
-J
Looking sick bro. So what did you do for the rear??
Username: BigBlue52
Date swapped: 4/14/16
Link to your build thread: will update when it is updated
Pictures to come soon!
I joined the club last week!
Devildogxd Titan Swap
I finally made the plunge and did the Titan swap after Gone Moab.
Just added the Alcan springs, what a difference, wish I would have done it long ago.
I'm finally titan swapped!
3.73 gears, M226, M205, 2.5" Radflo w/ remote reservoir, 3" alcans at #500 with 2" shackle. 295/75r16 KO2s. Will post pics soon..
My turn to post I guess.
Re geared c200k to 3.36, m205 in front, moog lowers, dirt king uppers, cardone axles, moog titan tie rods, radflo 2.5 coilovers.
Username: CGSonoma
Date Swapped: 14Jan2017
No build thread to come (didn't document it)
Front-
PRG UCA
Radflo 2.5 Coilovers
PRG Cam Bolts
PRG Extended Brake Line
Cardone Axles
M205 regeared to 3.36
Stock Titan parts (used and new):
LCA
Spindle/Steering Knuckle
Caliper and all mounting hardware
Slotted Disc brakes
Bearing/Hub
(I wanted the Titan Lug pattern and the bigger brakes)
Rear-
Regeared C200k with ARB Locker (rebuild kit and locker bought from RuggedRocks)
Spacers/adapters to get the 6 on 5.5 lug pattern
ALCAN 2" lift 200# over stock springs
Picture after swap:
TNX Veteran
