1 - 2 of 2 Posts
So I have been reading over the titan swap post and have a question on the required coil overs. They mention a spacer from alldayfab. Is it just a regular spacer that you use with the stock coil over? Dont want to spring for upgraded shocks and springs just yet. Just trying to piece it all together for the install.
TNX Veteran
Coilover length options for Titan swap:
  • Titan-swap length (the maximum length you can fit without other serious modifications)
  • Extended travel with a 1" spacer on top
  • OEM length with massive spacer on top (I don't think it has been done - you would need to modify the OEM coilover to accommodate such a spacer)
I would not recommend using OEM with TS. The spacer thing is more for people who already have extended length and just need a stop-gap. If you are starting from scratch, I would just wait a little longer. There is no benefit to Titan swap suspension without the correct coilover as you won't gain anymore travel.
1 - 2 of 2 Posts
