Not to make your decision harder, but have you considered the V8 Pathfinder brakes? They have a 1" larger rotor and from what I can tell the caliper bolts up to the stock location. You won't have to replace spindles or hubs like with a Titan swap.frosty said:Thanks guys! Yeah I figured it would be a project, I'm planning on the Stillen rotors and pads along with SS lines, should be more than adequate.
Hmm... that's interesting. It looks like you can't get a V8 pathy without an 18 inch wheel. I don't know how big that rotor/caliper combo would be, but would likely mean a wheel upgrade for most people. Good info, though.motor city x said:Not to make your decision harder, but have you considered the V8 Pathfinder brakes? They have a 1" larger rotor and from what I can tell the caliper bolts up to the stock location. You won't have to replace spindles or hubs like with a Titan swap.frosty said:Thanks guys! Yeah I figured it would be a project, I'm planning on the Stillen rotors and pads along with SS lines, should be more than adequate.
You would have to use the V8 caliper along with the larger rotors. It has a longer bracket.Muzikman said:If they are 1" larger the caliper bracket would have to change since there is no way it would currently clear a 1" larger rotor.
