Ho Ho Ho HO HOOOO! Did I hear Grounding kit? As in High Performance Grounding kit? As in the kind that reduces loss and drag from alternator and thus Up's the HP? Did I hear that? If I did I really really need a link and some pictures! Man! I hope I hope I hope! MCstevet47 said:Thats a bummer about it reverting when the battery is disconnected for a time. I have to disconnect my battery relatively often when I do wiring, I certainly would not want to loose the settings. Its a shame, we dont know exactly how long it takes to revert back. When I installed my grounding kit I know the ECU reset because my gas mileage went up significantly, and the battery was only disconnected for about and hour and a half.
usmc xterra said:Ho Ho Ho HO HOOOO! Did I hear Grounding kit? As in High Performance Grounding kit? As in the kind that reduces loss and drag from alternator and thus Up's the HP? Did I hear that? If I did I really really need a link and some pictures! Man! I hope I hope I hope! MCstevet47 said:Thats a bummer about it reverting when the battery is disconnected for a time. I have to disconnect my battery relatively often when I do wiring, I certainly would not want to loose the settings. Its a shame, we dont know exactly how long it takes to revert back. When I installed my grounding kit I know the ECU reset because my gas mileage went up significantly, and the battery was only disconnected for about and hour and a half.
Good news!!! so if i have them do this i will defiantly feel a difference. I don't want to ask them to do it and then have them not do it or not do it right.Devildog said:Got it done today. I can tell a difference. Similar to my titan, It's quicker out of the hole and feels like it pulls harder (I was surpised to see I made it to 60-70 mph as fast as I did when I entered the interstate) It was advanced 2 degrees and the tech swears up and down it will not revert back. The consult device set the timing + 2 degrees. It would take the consult to lower it or disconnetion of the battery for a period of time. (see below that was posted on the titan site). Well worth the 32 pesos of labor
There have been several questions lately on the timing reverting back after getting the 2* advance. This is not true!!! The timing will hold as long as you do not unplug your battery for any length of time. NIssan claims 24 hours, I have found it to be much much less. When I did my header install, I lost all programming that I had done and I had it unplugged for about 6 hours.
This will NOT void the warranty. It is within factory specs and is being programmed by the consult. The only scrutiny that can happen when it comes to consult programming is with the tech's certification. Since this is not involving a repair, you do not need to worry about this, so I will not go into detail.
When you program the truck with the Consult, whatever you program the consult to tell the ECM WILL stick as long as the consult and ECM "agree" that it is safe. I repeat, the consult and ECM will NOT allow you to do anything unsafe OR outside of the factory parameters. Example, if your stock timing is 15* and you try to program 20*, it will not take it. Even though the factory tolerance is 15* +/- 5*, it will only allow an adjustment of 2*. Meaning, you can take it from 15 to 17, no more.
If the service department that you are going to says it cannot be done or it will not stick or it will void the warranty, find somewhere else to go.
They can't F it up if they use their consult computer programmer deal. Make them print you out the results of the reprogram. Also make sure they adjust your engine timing.bikemanj7 said:Good news!!! so if i have them do this i will defiantly feel a difference. I don't want to ask them to do it and then have them not do it or not do it right.Devildog said:Got it done today. I can tell a difference. Similar to my titan, It's quicker out of the hole and feels like it pulls harder (I was surpised to see I made it to 60-70 mph as fast as I did when I entered the interstate) It was advanced 2 degrees and the tech swears up and down it will not revert back. The consult device set the timing + 2 degrees. It would take the consult to lower it or disconnetion of the battery for a period of time. (see below that was posted on the titan site). Well worth the 32 pesos of labor
Nonsense. They're lazybikemanj7 said:Well just tried to get it done at my dealer. They said that it is not worth it and if i got it done "i would come back down to have it readjusted when they change the gas over because it would ping."??? They were going to charge me 90$ so i said uhhhh no. So I'm going to try my luck at a different dealer.
