1 - 11 of 11 Posts
· on line
Just got off ths phone with Timbrin..They insist with a 2" SL on front..spacers are needed for the front as well,dont remember anyone mentioning that in threads..2" spacers for front and rear...No more freebies..40$ ! Any body??
· on line
Yea if the part number is the same as what I had, you would not be able to fit a spacer positively unequivocally without the slightest doubt. You can do the other ones I suggest at autozone. I think possibly B Slater has done both? And compared the two. Someone did and said Timbren was better but hey, you have an option. MC
· on line
You can't fit spacers and TimbrEns on in the front. They just won't work. In the back you will need the spacers, which the Timbrens come with. The front you just enlarge the hole and bolt them on. I used the Autozone stops and the Timbrens. The Autozone stops were 80% better and the Timbrens were 100% better. Knowing what I know now I probably would have just stuck with the Autozone stops.
· on line
Called them back and they insist spacers needed,, maybe different bump?we will see.they said i could send back if not,as always really easy to deal with.
· on line
If they (Timbren) are talking about 1/8" spacers, then it might work. Otherwise if the spacers are similar in size to the rear ones, it physically can't work.
· on line
Well, that kinda ticks me off, The ones they sold me work fine. Now are they selling him another part and ripping him for $40 spacers? Now that Slater chimed in with the 80 100, I'd go for the Autozone ones and only use Timbren in the rear. :angryfire: MC
1 - 11 of 11 Posts
