1 - 6 of 6 Posts
Front Diff only 1.9 pints, not quart's?
CAPACITIES
Engine, with filter..........5.4 quarts[1]
Cooling System, Initial Fill..........11.0 quarts
Automatic Transmission, Total Fill
5 speed RE5R05A..........11.0 quarts
Manual Transmission, 2WD..........8.4 pints
Manual Transmission, 4WD..........8.7 pints
Differential, Front..........1.9 pints
Differential, M226 Rear..........4.2 pints
Differential, C200 Rear..........3.4 pints
Transfer Case,..........4.2 pints
Discussion Starter #2
Well MC, I checked this out and yes they do! I ordered my oil service, hummm change oil every 8 months not a bad deal huh? I got the oil, EA filter, in cabin micro filter, Gas additive for the long haul, Sever gear for both diffs, and was that it? Amazingly cheap when you figure it out. MC
Everything looks good according to the FSM except for the transfer case which lists at 2 1/8 quarts.
Yea that was good for a laugh though. It just seems so Odd so little fluid is in there, I must be too used to working on my Big Truck, Trans took 5 gallons, Rears 3, Oil was 13. Can't wait for my oil to arrive MCampana is going to install it for me. JK. MC
lifeinthesouth said:
i think that's the same as 4.2 pts?
yeah, it was late, and that the was only one not on the same units
1 - 6 of 6 Posts
