Username: Jordan
My Youtube Channel: https://www.youtube.com/channel/UCVj4OHNyvZIjEEB9nqIYdFg
Year: 2008
Trim: Off Road T-Swap
Color: Avalanche White
315/75/16 Cooper STT Pro's
16x8" Pro Comp 7089 wheels
Shrockworks Front Bumper
InSain Fab Rear bumper with tire carrier
Shrockworks Radiator Skid
Shrockworks engine skid
Shrockworks T-Case Skid
Shrockworks Transmission Skid
InSain Fab Shock Skids
HeftyFab Sliders
Smittybilt XRC Comp 9.5 Winch
Xoskel Lo Pro Light Bar
Yakima Load Warrior Rack
Rugged Ridge 4" HID Lights (4)
Tail light guards
Sylvania Ultrastar Headlights
14" Murano rear wiper blade
Rear View Camera
STICKERS!
Wet Okole Seat Covers
Nissan Pet Guard Divider
DepHep Window Molle Panel
Fire Extinguisher
White Face Guages Nissan - Xterra - Whitegauges.net
175lb rear hatch struts
Performance:
XTP Intake Manifold Spacer
Airaid intake with Volant pre-filter
Poweraid Throttle Body Spacer
Optima Yellow Top
Drivetrain:
M205 Titan Front Diff
4.56s
ARB Air locker in M205
Titan CV Shafts
Shrock Diff Cover
2" Wheel spacers (rear)
Powerstop Slotted/Vented Rotors and Carbon Ceramic Pads
PRG motor mounts
Homegrown Rear Brake Relocator Bracket
Autopage Remote Start System
Locker Bypass Mod
Transmission Cooler Bypass w/ second cooler added
Diff Breather Extension
Jerseyparts 2" Body Lift
FRONT
PRG Titan Swap Kit
PRG UCA
Titan LCA
2.5" SAWs
PRG be heim steering rod ends
REAR
PRG Adjustable Rear Shackles
Alcan leafs +400lb/+4 in lift
Bilstien 5125s
Rear sway bar removed
PRG U Bolt Flip Kit
Nisstec 4 degree shims
Sitting in garage waiting to be installed:
Moog U Joints for Driveshaft
Harbor Freight Hitch Basket for use as rear cargo rack
Stock Form
After the 2" Revtek Lift
After the Titan Swap
After the body lift, bumper, and sliders Dec 2013
Rollin' on 35s and new rims Dec 2016
The Revtek Lift
Before the T-Swap
Ready for the T-Swap BEASTMODE VERSION 1.0
After the T-Swap
Homegrown Brake Bracket
BEASTMODE VERSION 2.0!
Year: 2008
HeftyFab Sliders
Tail light guards
Rear View Camera
STICKERS!
Fire Extinguisher
Performance:
Optima Yellow Top
Drivetrain:
4.56s
Titan CV Shafts
Shrock Diff Cover
PRG motor mounts
Locker Bypass Mod
FRONT
PRG Titan Swap Kit
PRG UCA
Titan LCA
2.5" SAWs
REAR
Bilstien 5125s
PRG U Bolt Flip Kit
Stock Form
The Revtek Lift
Before the T-Swap
After the T-Swap
