21 - 40 of 162 Posts
Discussion Starter · #21 ·
I'm getting ready for one of those necessary projects that I don't really want to do or pay for, the dreaded rubber coolant hose replacements. The mains are fine, I had the dealer change those when the timing chain job was done so this is basically everything else. Nissan hoses are pretty bulletproof in my experience so hopefully this will give me another 150k of no split hoses. Here's what I've ordered so far:
• Valve Cover to Valve Cover Hose. Part #11826EA200.
• Brake Booster Hose. Part #47474-EA000.
^Clamps for above x2. Part #16439-17B0A. Nissan says to replace the clamps too and since brakes are important I'll spend the extra 2 bucks without complaining too much.
• Brake Booster Check Valve. Part #47478-AX600.
• Coolant Bypass Hose (front of engine). Part #14055-EA200.
• Cam Solenoid gasket. Part #23797ZA000. When I replaced the valve cover gaskets I saw that it was was super brittle and although I didn't damage it I'm going to go back in and replace it anyway to prevent any more oil leaks.
• Heater Core to Reservoir Tank hose part 1. Part #21744EA000.
Heater Core to Reservoir Tank hose part 2. Part #21741EA000. These two are part of the same line that runs from the reservoir tank to the heater core. It runs under the fuse box and some other stuff so it should be fun to replace.
Discussion Starter · #22 · (Edited)
Last night I finally decided to tackle painting the metal center rear bumper. I've had the paint for a while, I bought everything from Automotive Touchup a while ago to repaint part of my front door that was chipping. That turned out great and I had a lot of paint left over so I wanted to use on the bumper since it faded into a greenish-grey mess. About a month ago I bedlined the plastic trim that goes on top of it and this matches it pretty well. Now I just need to buff the clear into a nice shine but here are some pics from a few minutes after the last coat.
The joy of working on a lifted truck haha
Discussion Starter · #23 ·
A dusty pic of just the bed-lined plastic bumper trim. This piece had some heavy oxidation so it took a decent amount of sanding to get it ready for the primer. I used some Rustoleum difficult surface or something primer along with their rattle can bed-liner. The texture is really nice, I was impressed with how it came out.
Discussion Starter · #24 · (Edited)
I've been busy on a few things lately, I pulled the secondary cats to get a look at those plus the primaries and make sure they were ok. All of them were fine, color is good and the honeycomb looked good. Only thing I noticed is on the passenger side the primary had two of the passages blocked? Hard to tell, there was a small white thing in them but it looked like it had always been there so I'm not sure if it matters.
Installed the fog light mod last night to make the stalk live anytime. I ordered a relay so I can alter it to be controlled by the auto power off feature so I don't accidentally kill the battery with it. I'm still getting a slight oil burn smell and it's been a month since I did the valve cover gaskets so I put it on the lift to take a look and found drops of oil on the driver side exhaust manifold. I needed to get a better view so I pulled out the fender liner and tried to unbolt the heat shield. All of the bolts broke so I just removed the shield entirely and cleaned everything up with some brake cleaner. After driving it a bit I'm going to go back and see if it's easier to spot where it's coming from.
Wrapped up the front end suspension work this morning with an alignment and tire balance at the dealer. Picked up bunch of body panel clips (30 cents each) and 2 o-rings for the passenger side camshaft and crankshaft position sensors while I was there.
Discussion Starter · #25 ·
My rear suspension was riding extremely rough so I pulled off the overleaf helper spring that I put on the front of axle section of the leaf pack. The ubolt plate kept working its way in between the leaves and blocking the pack from flexing upward. Hopefully this gets rid of the high speed rear end vibration I've been getting for a few months now.
Discussion Starter · #29 ·
Oil on the driver's side manifold...did you ever find out what this was from?
It took me a couple months of putting the truck up on the lift and taking pics, comparing pics, repeating that over and over until I finally was able to pinpoint it to the stock fluid filled engine mounts on both sides. But mostly the drivers side one. One clue was that after 'spirited' driving I noticed the oil burn a lot more and on other days not at all. I need to replace both mounts but haven't got around to it yet, that said though the oil is completely out of the mounts now and I don't have the problem anymore. 157k and not one oil leak!
Discussion Starter · #30 ·
Went camping over the weekend and did some forest service road exploring on the way home. It's nice to finally have a break from the summer heat. I grew up where the leaves stay green year round so I'll never get used to how nice the Fall season is up here, it's definitely worth driving to see.
Brought our pumpkin along because the thing was getting moldy after only a few days back home. Decided it wasn't a great idea to leave it out overnight in bear territory so it ended up permanently in the bear-proof trash can.
And finally got a shot of some new Philips Ultinon LED Foglight foglights I installed a few weeks ago before heading home.
Oh my, is that likely to get you hi beamed? Asking for a friend that runs his fogs all the time and wouldn't mind more light.
Discussion Starter · #32 ·
Not at all, I haven't been hi beamed once in the month I've had them. I have the fogs aimed correctly and the headlights are still halogen so there isn't much glare over stock.
Discussion Starter · #37 · (Edited)
Posting this How-To rough draft here until I have time to finish it and then I'll move it over to the how-to section.
I finally had time yesterday to work on a new ABS/VDC/TCS/EBD off switch mod and while I was only trying to get the ABS to turn off (the version 3 abs-off yaw sensor disable thread didn't work for me) the results ended up being worthy of a new thread. For the mod you'll need:
  1. Rocker Switch
  2. Bosch style relay
  3. Primary wire
  4. electrical connectors
  5. Wire stripper
  6. Zip ties/electrical tape, etc.
When everything was back together and I was testing the mod I found that if I turned the rocker switch on, the ABS/BRAKE/SLIP/VDC lights all came on and were disabled. I'm thinking ok great, that's what I wanted. But with the truck still running I flipped the rocker switch off and both the ABS and Brake lights turned off. I was like wait a second and flipped the switch back on, both the ABS/BRAKE lights turned on again. Then I flipped the switch off again and the ABS/BRAKE lights both turned off again. This mod gives you the ability to turn the Anti Lock Brakes and Electronic Brake Distribution on/off just by flipping a rocker switch, no truck restart required. I should also note that at least for now you will still have to restart to re-enable the VDC and TCS although I plan on getting rid of that requirement in a future update.
Section 1: Systems Background Info
It helps to be familiar with the systems on the X so to start I'm going to talk about the different systems the X has and what they do so you'll have a reference guide for the terminology used and get a better idea of what what you're dealing with. The Xterra has multiple electronic driving aid systems, some trim levels may have additional systems like Hill Start (HSA) and Hill Descent Assist (HDC). But everyone should have Anti Lock Brakes (ABS), Electronic Brake Distribution (EBD), Traction Control (SLIP), and Vehicle Dynamic Control (VDC). Here's a look into what those systems do:
ABS
● The Anti-Lock Brake System detects wheel revolution while braking and improves handling stability during sudden braking by electrically preventing wheel lockup. Maneuverability is also improved for avoiding obstacles.
● If the electrical system malfunctions, the Fail-Safe function is activated, the ABS becomes inoperative and the ABS warning lamp turns on.
● The electrical system can be diagnosed using CONSULT-II.
● During ABS operation, the brake pedal may vibrate lightly and a mechanical noise may be heard. This is normal.
● Just after starting the vehicle, the brake pedal may vibrate or a motor operating noise may be heard from engine compartment. This is a normal status of operation check.
● Stopping distance may be longer than that of vehicles without ABS when vehicle drives on rough, gravel,or snow-covered (fresh, deep snow) roads.
EBD
● Electronic Brake Distribution is a function that detects subtle slippages between the front and rear wheels during braking, and it improves handling stability by electronically controlling the brake fluid pressure which results in reduced rear wheel slippage.
● If the electrical system malfunctions, the Fail-Safe function is activated, the EBD and ABS become inoperative, and the ABS warning lamp and brake warning lamp are turned on.
● During EBD operation, the brake pedal may vibrate lightly and a mechanical noise may be heard. This is normal.
TCS
● Spinning of the drive wheels is detected by the ABS actuator and electric unit (control unit) using inputs from the wheel speed sensors. If wheel spin occurs, the drive wheel right and left brake fluid pressure control and engine fuel cut are activated while the throttle value is restricted to reduce the engine torque and decrease the amount of wheel spin. In addition, the throttle opening is controlled to achieve the optimum engine torque.
● Depending on road condition, the vehicle may have a sluggish feel. This is normal, because optimum traction has the highest priority during TCS operation.
● TCS may be activated during sudden vehicle acceleration, wide open throttle acceleration, sudden transmission shifts or when the vehicle is driven on a road with a varying surface friction coefficient.
● The SLIP indicator lamp flashes to inform the driver of TCS operation.
VDC
● In addition to the ABS/TCS function, the driver steering amount and brake operation amount are detected from the steering angle sensor and pressure sensors, and the vehicle's driving status (amount of understeering/over steering) is determined using inputs from the yaw rate sensor/side G sensor, wheel speed sensors, etc. and this information is used to improve vehicle stability by controlling the braking and engine torque application to the wheels.
● The SLIP indicator lamp flashes to inform the driver of VDC operation.
● During VDC operation, the vehicle body and brake pedal may vibrate lightly and a mechanical noise may be heard. This is normal.
● The ABS warning lamp, VDC OFF indicator lamp and SLIP indicator lamp may turn on when the vehicle is subject to strong shaking or large vibration, such as when the vehicle is on a turntable or a ship while the engine is running or on a steep slope. In this case, restart the engine on a normal road and if the ABS warning lamp, VDC OFF indicator lamp and SLIP indicator lamp turn off, there is no problem.
HDC
● The hill descent control system will help maintain vehicle speed when driving under 25-35 km/h (15-21 MPH) on steeper downhill grades. HDC will provide braking allowing the driver to concentrate on steering while reducing the burden of brake and accelerator operation.
● To operate the system, set the 4WD switch to 4H or 4 LO and push the HDC switch. The HDC indicator in the combination meter will turn on. While HDC is operating, the stop/tail lamps will illuminate.
● If the accelerator or brake pedal is depressed while the HDC system is on, the system will stop operating.
● During HDC operation, a mechanical noise may be heard. This is normal.
HSA
● The HSA system will assist the driver by applying the brake automatically and preventing the vehicle from rolling backward when starting on an uphill.
● The maximum holding time is 2 seconds. After 2 seconds, the vehicle will begin to roll back gradually and then HSA will stop operating completely.
Fail Safe Modes
There are two fail safe mode that can be activated. You can tell which one has been activated by the dash lights illuminated:
1. In case of an electrical malfunction with the ABS, the ABS warning lamp, VDC OFF indicator lamp and SLIP indicator lamp will turn on.
2. In case of an electrical malfunction with the EBD system, the BRAKE warning lamp, ABS warning lamp, VDC OFF indicator lamp and SLIP indicator lamp will turn on.
Once Fail-Safe Mode has been activated certain dash lights will illuminate. You can tell what has been disabled by what lights are on, for example if SLIP/VDC are illuminated that means traction control and stability control are off but the anti lock brakes and electronic brake distribution are still on. Here are the results of fail-safe mode on the different systems:
ABS/EBD Fail-Safe Modes
1. For ABS malfunction, only the EBD is operative and the condition of the vehicle is the same condition of vehicles without ABS/TCS/VDC system.
2. For EBD malfunction, the EBD and ABS become inoperative, and the condition of the vehicle is the same as the condition of vehicles without ABS/TCS/VDC or EBD system.
HDC/HSA Fail-Safe Modes
● In case of HDC system malfunction, the HDC indicator lamp will remain off even though the HDC switch is operated and the condition of the vehicle is the same as the condition of vehicles without HDC system.
● In case of HSA system malfunction, the VDC OFF and SLIP indicator lamps are turned on and the condition of the vehicle is the same as the condition of vehicles without HSA system.
VDC/TCS Fail-Safe Modes
In case of TCS/VDC system malfunction, the VDC OFF indicator lamp and SLIP indicator lamp are turned on and the condition of the vehicle is the same as the condition of vehicles without TCS/VDC system. In case of an electrical malfunction with the TCS/VDC system, the ABS control continues to operate normally without TCS/VDC control.
Section 2: System Layout
The way the system is set up the abs brain under the hood receives a variety of date from the wheels, steering, etc that it uses to make decisions. For the mod we need to disrupt that data flow to trick the system into a Fail-Safe mode. After reading through the FSM I decided to to focus on the brake signal input. The system can’t activate if it doesn’t know when the brakes are being applied and it seemed like one of the less complicated systems to mess with. Here are a few diagrams of the wiring layout and the harnesses on both the brake side and the abs brain side:
Section 3: The Mod
So now to the good stuff, the actual mod. I followed the instructions in the ABS off Version 3 mod for the configuration of my rocker switch. The switch has a 12v input, a ground, and a power out (the part of the switch that sends power). The power out runs to a single relay, here’s a couple sketches of my wiring setup. Disregard the notes about the Yaw sensor:
Just like in Phulld's version 3 mod this switch and relay combo is set up to disrupt the connection of a wire. With the switch off, the system functions normally, with it on the connection is broken, the abs brain senses something wrong and puts the system in fail-safe. However unlike in the version 3 mod we don’t touch the Yaw Sensor wiring and instead go straight to the abs brain.
Open the hood and locate the abs controller harness, it’s near the driver side firewall. The harness itself has two latches that have to be pulled up/down to release the harness. Be careful with it the tracks get full of dirt and dust and don’t like to slide easily (at least on an 06). With that disconnected use a small pair of scissors or a knife to cut away at the wrapping on the wire bundle but make sure not to knick and of the wires.
Locate the sky blue wire with the silver dash marks. That’s the brakes ‘on’ input wire.
I made sure I had sufficient slack to attach connectors and then snipped the wire, reconnected the harness and turned the truck on to test. All of the right dash lights were on so went back and connected a wire to each end of the wire I cut. Then I ran those wires back through the firewall and to my relay. The wire end going into the abs brain goes on connector 87a and the end coming from the truck goes to connector 30. The way it works is you flip the rocker switch, it sends power to the relay and connector 30 is switched to connector 87. Given we don’t connect anything to 87 the signal becomes a dead end. Make sure you secure all of the wires you ran and re-wrap the abs wiring harness so you keep everything protected.
And that’s it! Remember this mod is no restart required to re-enable the ABS and Brake Distribution but to reactivate the VDC/SLIP you will need to restart. I’m working that one out now, my goal is to get rid of the restart completely. Happy modding!
Discussion Starter · #39 ·
Last week I tried out some ideas I've had about how to make the seats more comfortable and had pretty good results with it. I pulled out the front two seat bottoms (only 4 12mm bolts holding them in and two clips to pull for removing the adjustment wheels on the side) and took a memory foam pillow ($15 from Marshalls) and cut it into pieces to add to the side bolsters and seat bottom areas.
After that I unzipped the driver side seat back and pushed some foam up into the side bolsters there too. It's made a huge difference, by adding taller foam (~1.5") to the flat section nearest the front of the seat it created a more bucket seat like feel. The passenger seat is way better too as reported by my gf who never held back in telling me how bad it was before haha. I think I might try to create some fake bolsters in the rear seats, I've never been a fan of the bench seat that everything slides off of. Anyway, here's a few pics from the process:
Turns out Calsonic made more than just our radiators.
Discussion Starter · #40 ·
We went camping out on a WMA over the weekend and I was finally able to try out my new abs/ebd/vdc/slip disable switch. This was a good test since I was on this same road about a month or two ago without the switch and it was really sketchy going down some of the steep drop offs with the abs chattering and no ability to stop.
This time was a HUGE improvement and the road was actually in worse condition due to some recent storms, lots of slick clay but the truck handled it no problem. I looked out the window early on and saw my front wheel was locking like it should on the steep downhill sections. Best part was the out-of-control/can't-stop feeling was gone which let me actually maneuver the truck down the hills. I wish I would have done this mod years ago!
