What you are wanting to do will accomplish what you want to do.
But that is NOT "full suspension travel" / "maxing out".
Your sway bar and springs will limit you. You're figuring out a 'static flex'.
You'll see more travel nose down into a ravine or bouncing weight, or a LOT more bouncing nose down (especially so if you bounce BOTH sides so the sway bar isn't fighting it)
Also, you'll likely start lifting a 2nd tire fairly quickly. You MIGHT consider putting the opposite corner on a ramp to initiate more weight up front. Not sure on that though.
Ramp tests and fork lift testing is just for the basics... you'll see a lot more movement while wheeling. They are parking lot flexing, literally and figurately.
