Switches and You
21440 Views 24 Replies 21 Participants Last post by  ronaprhys
Switches and You
Selecting a Switch
There are three important features to consider when selecting a switch:
• Contacts (e.g. single pole, double throw)
• Ratings (maximum voltage and current)
• Method of Operation (toggle, slide, key etc.)
Switch Contacts
Several terms are used to describe switch contacts:
• Pole - number of switch contact sets.
• Throw - number of conducting positions, single or double.
• Way - number of conducting positions, three or more.
• Momentary - switch returns to its normal position when released.
• Open - off position, contacts not conducting.
• Closed - on position, contacts conducting, there may be several on positions.
For example: the simplest on-off switch has one set of contacts (single pole) and one switching position which conducts (single throw). The switch mechanism has two positions: open (off) and closed (on), but it is called 'single throw' because only one position conducts.
Circuit symbol for a simple on-off switch:
Switch Contact Ratings
Switch contacts are rated with a maximum voltage and current, and there may be different ratings for AC and DC. The AC values are higher because the current falls to zero many times each second and an arc is less likely to form across the switch contacts. For low voltage electronics projects the voltage rating will not matter, but you may need to check the current rating. The maximum current is less for inductive loads (coils and motors) because they cause more sparking at the contacts when switched off.
Standard Switches
____________________________________________________________________________________________
ON-OFF; Single Pole, Single Throw = SPST
A simple on-off switch. This type can be used to switch the power supply to a circuit.
When used with mains electricity this type of switch must be in the live wire, but it is better to use a DPST switch to isolate both live and neutral.
SPST toggle switch
(ON)-OFF; Push-to-make = SPST Momentary
A push-to-make switch returns to its normally open (off) position when you release the button, this is shown by the brackets around ON. This is the standard doorbell switch.
Push-to-make switch
ON-(OFF); Push-to-break = SPST Momentary
A push-to-break switch returns to its normally closed (on) position when you release the button.
Push-to-break switch
ON-ON; Single Pole, Double Throw = SPDT
This switch can be on in both positions, switching on a separate device in each case. It is often called a changeover switch. For example, a SPDT switch can be used to switch on a red lamp in one position and a green lamp in the other position. A SPDT toggle switch may be used as a simple on-off switch by connecting to COM and one of the A or B terminals shown in the diagram. A and B are interchangeable so switches are usually not labelled.
ON-OFF-ON; SPDT Center Off
A special version of the standard SPDT switch. It has a third switching position in the centre which is off. Momentary (ON)-OFF-(ON) versions are also available where the switch returns to the central off position when released.
SPDT toggle switch
SPDT slide switch (PCB mounting)
SPDT rocker switch
Dual ON-OFF; Double Pole, Single Throw = DPST
A pair of on-off switches which operate together (shown by the dotted line in the circuit symbol). A DPST switch is often used to switch mains electricity because it can isolate both the live and neutral connections.
DPST rocker switch
Dual ON-ON; Double Pole, Double Throw = DPDT
A pair of on-on switches which operate together (shown by the dotted line in the circuit symbol).
ON-OFF-ON; DPDT Centre Off
A special version of the standard SPDT switch. It has a third switching position in the centre which is off. This can be very useful for motor control because you have forward, off and reverse positions. Momentary (ON)-OFF-(ON) versions are also available where the switch returns to the central off position when released.
DPDT slide switch
There are of course many other types of switches but I think these would cover most things we might need in our Xs. :salute:
1 - 20 of 25 Posts
Excellent! This will be used by me hopefully in the near future...
Nice write up. Clears a lot of things up for my simple mind. :)
Sent from the Situation Room
I must say that is the best descriptions I have ever read !
It is easy to understand but very complete at the same time.
Nice work !
at first I wondered how I ever missed this. Then I realized it was a recent post.
Very nice. Thanks!
Thanks OZ! I am trying to teach myself enough to work on putting in my own lights and switches in my truck. This was very helpful!
Very nice...thanks for dumming it down for us folks who need a translator for wiring diagrams lol
Very helpful thanks, I have a great mod idea coming for the X hopefully gunna get it done really soon and this definitely helped!
where can i find the OEM roof light switch? or what part number is it?
If i'm not mistaken the oem roof lights come on with the highbeams?
So if that is true, there isn't a switch, it's the stalk/wiring you'll need.
There are many switches that have an OEM look to them however. I'm pretty sure people fit in Toyota switches in their Xs, however i went the OTRATTW route, and I am happy I did. They are a vendor here and they are top notch switches.
dont like the OTRATW look, rather have a toyota switch that looks more OEM, but the switches i want are kinda like these, i thought they were OEM that came with the roof lights. were can i get dimensions of the switches that will fit? i know i saw that in a post in here but cant find it anymore, thanks for your help.
http://www.google.com/imgres?q=xterra+roof+lights+switches&start=90&hl=en&complete=0&gbv=2&biw=1024&bih=625&tbm=isch&tbnid=A8Gvq5qPBAwz6M:&imgrefurl=http://www.clubfrontier.org/forums/f23/xterra-offroad-lamp-switch-58898/&docid=KZqDHke3u5tXqM&imgurl=http://www.clubfrontier.org/forums/attachments/f10/26671d1271184230-new-piaa-lighting-2010-04-13-11.32.08.jpg&w=2048&h=1530&ei=ix_ET9maNofm9ATBipyhCw&zoom=1
I've got a bit of a question for this thread: I'm seeing OTRATTW switches out there that have two bulbs (yes, the zombie lights). It appears that the lower light could be set up to come on when I turn the headlights on, then the upper goes on when I turn the actual lights themselves on by putting the switch in the ON position.
I know folks have wired this sort of a deal up before, but for those of us noobs, anyone got a diagram or any useful hints?
BTW - I'm thinking an SPST Two Pilots, one dependent one independent is the switch necessary for this sort of set up.
For those wondering, the OEM off road lamp switch is a momentary (push to ON). Same with the VDC OFF I believe.
Upon reading the FSM, what happens is the button is used to send a signal to the BCM which -when all parameters are met- will send the signal on to the proper relay assembly and switch on the lamps. It is NOT a push-on-push-off type.
I sure wish i'd have known this before dropping $25 at the dealer.
So... I've been thinking about aux lights and where to put the switches. I'd like to have a rear facing light above the lift-gate (either xoskel, or dephep mounted). It makes sense to me to put the switch to activate this adjacent to the front facing roof lights switch (left of the steering wheel on P4X Offroad models). It even makes sense to me to match the OEM "roof lights" switch.
Question, can an OEM switch (which is momentary) be wired to operate the rear facing light? It should.. because that's what the front facing OEM roof light switch does, only difference being that the front lights are interconnected with the high beams and the rear light would be connected to be on when I want it (and ignition).
Debate:
1) how will you know which switch to use if they are exactly the same?
ANS: The same way I know if the front or rear wipers are going.. hit the switch and see what happens
2) what if your wife borrows the truck and somehow turns the rear light on and other drives start honking at her and giving her the finger?
ANS: and how is that is different from her usual driving? OK.. good point.. I will consider the consequences of this action after I find out if it is doable.
Experts please chime in.
Saint Urho: I have an OEM OR light switch sitting on my kitchen counter. replaced the switch with one of the OTRATTW ones. if you want send me a PM and we can work something out
Does anyone know if this switch will work for an offroad light setup, or it is just another momentary switch like the factory Xterra switches? Im looking for a true OEM style look for a switch for my offroad lights, but I dont want to have to come up with some crazy wiring to make it work.
http://www.ebay.com/itm/Push-switch...ies&hash=item3a88f1ecf4&vxp=mtr#ht_5966wt_801
Thanks!
has anyone ever found switches like these? this is a kenworth switch so not a universal/adaptable fit, but I prefer the "flick" rockers over the push ones. Lots of cheap flick switches but nothing that looks clean like these!
Just some of the rocker switches I have been using...
1 - 20 of 25 Posts
