1 - 13 of 13 Posts
· Registered
Username: SuperSlideStyle
Year: 2013
Trim: PRO4X 6 spd 4WD
Color: charcoal gray (Midnight Armor)
-OME HD Dakar coil & leafspring set
-Bilstein 5100's front/5165 remote reservoir rear's, OME shackles urethane bushing
-PRG UCA's, poly-urethane sway bar bushingsheim steering linkage, heim sway bar bracket
-PowerStop slotted/cross-drilled rotors, Ceramic pads, extended steel-braided brake lines
-295/75R16 Nitto TerraGrappler tires
-K&N intake, ebay Snorkel kit, ported/polished throttle body
-DENSO ignition coils, NGK Iridium plugs
-JWT lightened flywheel/clutch combo
-CSF all-aluminum 3-row HD radiator, NISMO radiator caps, Mishimoto racing Thermostat, HPSsilicone coolant & vacuum hoses
-Aeromotive Stealth hi-flow racing fuel pump
-Oddessey battery, 150A dist block, two 30A fused dist. Blocks, all bulbs swapped to LED type
-LED 5k headlights, LED 3.5k foglights, LED YLW front aux. driving lights, HID H11 PRO-4X roof lights, twin 13" LED light bar in front, twin rear LED roof lights, quad LED side roof lights
-Cobra 29LTD Classic cb radio, FireStik II antenna
-Custom-built (by me) rock sliders, rear hatch ladder, shovel/axe roof bar mount, front light bar, functional hood vents
-100+ velcro patches on ceiling, 100+ stckers on body
Tire Sky Wheel Land vehicle Vehicle
· Registered
Discussion Starter · #6 · (Edited)
-PowerStop slotted/cross-drilled rotors, Ceramic pads, extended braided brake lines
-K&N intake, over-bored throttle body
-RS plasma ignition coils, NGK Iridium plugs
-NISMO radiator caps, Mishimoto racing Thermostat, Kemso hi-flow racing fuel pump
-ebay Snorkel kit, HPS hoses & clamps
1 - 13 of 13 Posts
