1 - 8 of 8 Posts
Hey Guys,
Whats involved with installing the sunglass holder on my S? Anything really tough?
Thanks
Shane
I thought there was a how-to on here but i just checked Cornicks's list and it's not on there... It might be on that other site!
Looks like as long as you measure right you can't really screw it up.
I did it the other day. you need a box cutter/razor to cut out the space, make sure you cut out slightly wider spots at the end where the gear and spring are. also you need a dremmel or little hand saw or something like that to cut the metal crossmember. took about an hour max.
did mine yesterday in about 10 min. Like said before, tin snips will work just fine. Looks just like factory!
1 - 8 of 8 Posts
