Without warning or symptoms my 2008 automatic X won't start...
- battery tested and is good
- checked cables & corrosion throuought battery to starter circuit
- turn key = single click
- all power works besides starter and headlights don't dim when key is turned
- jumpstart doesn't work
- loosened starter from flywheel, when key is turned the gear protrudes from starter but won't spin
- the starter gear will spin by hand
- motor is not locked up
I went ahead and removed the starter so I can go get it tested, even though I pretty much already tested it. So my question is... Is there some other relay or fuse that keeps the starter from spinning even though it can still protrude when you put power to it? Sorry for the long post. I wanted to avoid all the usual ("your an idiot who doesn't know how to check a battery") comments.
