1 - 9 of 9 Posts
I just got new sway bar end links, as i left the 4 bolts that hold the sway bar on the frame screwed in so i wont lose them, some how both bottom bolts stripped while trying to install the sway bar back on. They wont go more then 1/4th inch and im so pissed off. Any remedies please? Even with 600ln coils n radflos the sway from the front while driving is abit much for daily use. If i cant fix it ill just have to live with it but is there any way to fix this?? Its pretty much a welded on nut.
Banned
Stripped bolt, any fixes?
Tap/die set. Run a die over the bolt to clean the threads.
Sent from AutoGuide.com App
I'm sure there are more sizes... but pretty much everything on the truck I've hit is either 10mm, 12mm, 15mm, or 17mm.
1 - 9 of 9 Posts
