1 - 11 of 11 Posts
i gotta a question I just made a ram air for my stock airbox and ran it through my fog light opening should I worry about water vapor getting into my airbox, rain shouldnt be a problem a low speeds but i mean at highway speeds. with heavy rains
oh yeah i got that mixed up i was thinking ram cause its forcing air in im thinking about sticking some sort of filter on the end of the tube that comes into the airbox
:clown: Fraid our buddy is right-COLD AIR-
xterramo said:
Don't you mean COLD AIR
--You can't construct a RAM AIR intake, using the Xterra front (square) face design !!
--It would have to be on top the HOOD and then, it would be of no use below 90 mph (if then) !!
-- :geek: :geek: --JIMBO
well then its a cold air intake I like it, it changed the exhaust note and made it a little deeper because i did that and dropped in a k&n filter. I did make a foam cover for the inside of the airbox so if moisture does get in. In theory it will soak into that and drip off
1 - 11 of 11 Posts
