1 - 20 of 20 Posts
So I have gone through the checklist as follows:
Alignment
Wheel/Tire Rotate and Balance
Checked for play in lower balljoints
Checked Tie Rods (I actually just had my steering rack replaced)
The steering wheel shakes like a mofo at about 65 and doesn't really improve if I increase speed (up to about 80 anyway)
My shocks seem fine, I slam on the brakes (at like 5 mph) and it doesn't keep bouncing. Just a tiny bit, but that's from the air in the tires acting like a spring.
The only thing that's left is the possibility of a bent rim right? I don't necessarily take any special precaution against bumps. I do try to avoid craters in the road, but I think I might have hit one between my alightments (about a month apart) and town fair said my alignment and balance was out.
Anything else cause the shake? I don't have new tires or anything. Maybe the dealer torqued my wheels to tight and warped them? IDK but this is really annoying on the highway.
Thanks for any input guys!
Sounds like it may be u-joints. I have had this before at higher speeds (front u-joint issue) and just had it at lower speeds (rear u-joint issue). Check them.
I couldn't feel any play when checking them by hand under the X. It wasn't until I dropped them that I saw the issue - here is the rear I just changed. I was getting mad vibes at 40-55mph. My needle bearings in one cap were more like needle dust.
I'm not sure how that would affect the steering shake though. I also had my front diff replaced under warranty.
If the bearings in the U-Joint are disintegrated like above it is still hard to feel the play, but your drive-line is supposed to be 100% balanced and the U-joints would cause the vibration.
Discussion Starter · #10 ·
Were your tires balanced then rotated or rotated then balanced? My truck drove nice and smooth until my last tire rotation and now there is a bit of a steering wheel shake at higher speeds.
I had Town Fair Balance and Align, but not rotate. So the shake was there before and after. I'll probably try rotating today.
Have you replaced the U-Joints in the front drive shaft? I know your X is pretty new but if it has higher mileage it could be it. Either way you can drop the front shaft with 8 bolts (14mm) and take it for a spin to see if it stops; make sure to mark both flanges so you reinstall in the same place.
I have a similar issue that shows up at hwy speeds. Gone over the same list of items but the wheel shake continues. I see the explination, worth the effort for the sake of 8 bolts. I'll report back when I've tested this out.
Cheers.
Because our 4wd system power runs through the Transfer Case (not locking hubs and stuff like that) our front drive-shaft and differential are always spinning with the rear drive-shaft even though there isn't any power going to the front drive-shaft from the TC in 2wd. So by removing the front drive-shaft you are taking the 2-ujoints out of the equation and you can drive without it connected to see if the vibration goes away (if it does it is a feeling of excitement that many of us have experienced)!!
I had 2 different sets of gears in my rig while I was swapping the rear axle, by disconnecting the front drive-shaft I was able to install the new r180 with 3.36 even though my c200k was 3.13 and be able to drive it around. It just enabled me to get a head start on the install process...
Rock Auto is a good place to get them. Really easy search engine to find what you need and shipping is typically fast.
1 - 20 of 20 Posts
