Staun Tire Deflators cost me about $60 and have been very useful. It took me a while to justify $60 on something that just deflates my tires but if you off-road a lot, you know how annoying it is to deflate with just a pressure gauge.
They thread onto your tires' valves stems and deflate all of your tires to your desired, preset pressure. You can adjust the preset pressure from 6 to 30 PSI and the setting can be changed an infinite number of times. They're constructed from solid brass for both corrosion resistance and resilience.
* fully adjustable without the use of tools from 6 to 30 PSI
* preset to 18 PSI
* desired pressure can be reset an infinite number of times
* suitable for all types of offroad vehicles
* fast and accurate
* solid brass construction
* attractive design
https://www.expeditionexchange.com/staun/
________
WENDIE 99
* preset to 18 PSI
* fast and accurate
* attractive design
________
WENDIE 99
