1 - 6 of 6 Posts
I recently did a titan swap and installed extended ss brake lines from PRG. But they seem to be rubbing on the wheels on the inside. I can move them away but they will eventually move back to rubbing when I turn the wheels. Is there a way to position them in a way they don't rub, or is there a way to use a strap/clamp to prevent them from moving toward the wheel. Maybe a zip tie?
Thanks
Discussion Starter · #2 ·
Ok, got it fixed... Moved the brake line more toward the spindle and ziptied it to the abs wiring. Drove it around for a bit, and it seems to stay and not move toward the wheel and rub. All is good.
Yea, for a while I had no idea where the sound was coming from. But worked like a charm... lol
1 - 6 of 6 Posts
