1 - 20 of 40 Posts
Something started squeeking over the weekend - pretty loud on the way to work this morning. Sounds like a belt of somekind, not opened the lid yet to investigate as I was already running a little late for work. I just hit 7100miles over the weekend, I guess its back to the Dealershit tomorrow :(
I believe it might be the belt tensior that is causing the problem. I missed my appointment the other week so I need to make another one. Not sure when. I have to get them to fix the window, the ac compressor line is coming loose again and when ever the belt gets wet it squeals.
Mine didn't get wet. Just the opposite, its been bone dry & dusty for the last few days. Plus I went out shooting on a dusty desert trail on Saturday, don't think its a Wet problem here.
Luckily I just got setup at work with VPN access so I can work from home tomorrow, otherwise I'd bemore pissed about taking a day off.
Yupp, there really is no reason at all why half of the people who work here are actually here in the building. 99.9% of my job can be done from home over VPN.
My belt started squeaking a while back (at about the 5000 mile point) and I asked the dealer to check the belt and the tensioner. They replaced the belt and I haven't had a problem since.
Discussion Starter · #10 ·
Dealer replaced the belt and tensioner.
Refused to look at the other high rev gear change / rattling issue as they want me to remove the aftermarket tow hitch first, as it occasionally rattles against the exhaust (Dumbasses).
You're kidding right? I hope that your hitch doesn't rattle. If that is the case then why didn't they tighten everything down and go from there?
G
i don't think tightening the hitch hardware would prevent the tail pipe from coming in contact with the hitch.
Discussion Starter · #13 ·
No - the hitch itself doesn't rattle. Its just real close to the exhaust, which when you crank the engine sometimes rattles against the hitch. I might try losening the hitch however and see if I can't adjust it a little away from the exhaust. If not, then I guess I'm just gonna have to buy a new muffler! :)
Back to belts.
Mine squeaks like the whore you had last night!
Did your dealer have a belt in stock?
I been waiting like 5 Days.
Back in the old days, we would have took a belt off a new car and transferred it until one came in and just replaced the harvested one.
Anyone ever find an aftermarket Gator type belt let me know. If this belt is only lasting 5 to 15 K when a belt like this should last at least 100K
There is something wrong with the materials of the belts they use.
I have a Cadillac the belt started to squeak at like 140K It was still good as far as looks, but squeaked. I expect at least 100K out of a belt.
Dan, was the belt your problem or was it the tension er?
MC
I think it's the belt. It does it a lot when it gets wet and what not. I say that because it goes away after it dries off.
Funny how people are talking about the squeeky belt when wet.... About a week ago my belt started to sing out so when I got home I just hit it with a quick shot from the hose (awfully dirty in the engine compartment) and since then no problems. Usually I've found that dust is more likely the culprit. On the same note, my squeeky rear suspension was most likely due to the same issue. While I had the hose handy I managed to coerce about 10 lbs of WV mud out of the radiator, skidplates and suspension components. Didnt realize I still had so much of the crap around.
Yea, My dealer ordered the belt, by time it came it, it stopped. Mechanic said "Contamination" was the culprit. Makes sense, as i did clean it with orange clean and it stopped shortly after that, Like a day or so. Hot Rod it a bit, It will stop.
I don't think it's the tensioner, because if you squirt the belt the noise changes. If it was the tensioner, it wouldn't change the noise. MC
Discussion Starter · #19 ·
Mine has been fine since they replaced the belt (Yes they had it in stock) and the tensioner. Put about 2.5k miles on her since then.
1 - 20 of 40 Posts
