Most vehicles come with unmatching spare tires, so, I would think that there would be no harm if you just use it for few miles.trevluk said:What is the consensus of having a stock 265 spare when running 285's? What kind of damage could be done using the slightly smaller spare?
While this is usually true, my understanding is that the diameter of the spare still matches the diameter of the stock vehicle tires in most cases. This is going to be the most important size measurement when you consider the effects on a differential. For anything more than a few miles you don't want a significant difference in diameter.sherpa said:Most vehicles come with unmatching spare tires, so, I would think that there would be no harm if you just use it for few miles.
I wouldn't think so, but I'm no tire expert either (I'm good with rules of thumb, but not so good with the numbers part). I'm thinking there's a size difference percentage-wise that you should never go beyond, but I'm not sure what it is.miles said:a 265 MTZ and a 265 AT spare shouldnt make a big difference...should it?
