1 - 3 of 3 Posts
hey guys, i have the mod itch again and want to do a lift.
i've tried searching but couldn't get a definate answer to my question which is:
on a 2wd xterra ('07 S), would uca contact be less likely than having a spacer on a 4wd?
if so, can i get away with using the calmini 2.5"-3" lift?
Re: spacer lift......2wd xterra.....uca contact less likely?
It is less likely on a 2wd but there's a catch... if you go with a spacer made for a 4wd (i.e. Dasytar, TGC) there will be virtually no contact because they only lift approx 2-2.5" but if you go with one like the PRG or Clamini designed specifically for 2wd the contact will be about the same as a 4wd spacer on a 4WD
To clarify... PRG and Calmini make them for both 2WD and 4WD
1 - 3 of 3 Posts
