1 - 12 of 12 Posts
Last week at the 2013 SEMA Show in Las Vegas, we introduced a whole bunch of new winching accessories. Designed to perform and to look great, these new winching accessories have features and benefits that will help you "GO PREPARED" for any situation on the trail. Let's have a look at the products that were introduced.
WARN Premium Hook
The WARN Premium Winch Hook with Cerakote coating provides maximum protection and reliability against wear and abrasion. It's also been uniquely designed with a built-in beverage opener. This forged hook is available in three varieties: For 18,000 lb. capacity winches and under; for 10,000 lb. capacity winches and under; and for 5,000 lb. capacity winches and under.
WARN Premium Shackle
The clevis shackle provides a means for connecting the looped ends of cables, straps, and snatch blocks. The shackle's pin is threaded to allow easy removal. For maximum protection against wear and abrasion, the premium shackle uses Cerakote coating. There are two versions available: One for 18,000 lb. capacity winches and under, and one for 5,000 lb. capacity winches and under. Both are forged.
Premium Snatch Block
Coated with Cerakote and able to accept both wire and synthetic rope, the forged Premium Snatch Block is reliable, durable and ready for action. When used properly, the multi-purpose snatch block can double the pulling power of any winch or change your pulling direction without damaging the rope. It also helps to reduce heat buildup and amp draw during recovery. Buyers can choose from a block rated to 12,000 lbs. or one rated to 5,000 lbs.
Premium Tree Trunk Protector
The Premium Tree Trunk Protector Strap is designed to help protect a live tree from damage during winching operations and self-recovery situations. The strap is constructed of premium quality nylon with an encased red warning marker to indicate damaged webbing. Plus, the end loops are reinforced with durable forged ring connectors and coated with Cerakote for premium protection against wear and abrasion. Three varieties are available including a 4" x 8" Tree Trunk Protector rated to 30,000 lbs.; a 2" x 8' Tree Trunk Protector rated to 14,400 lbs.; and a 1" x 8' Tree Trunk Protector rated to 7,200 lbs.
WARN Winch Damper
The WARN Winch Damper helps to prevent rope recoil in the event of a rope failure, which is a pretty rare occurrence. However, if it were to happen, this damper will help the rope fall to the ground if such an event were to occur. Made from durable vinyl, the WARN Winch Damper also features a pocket for rigging accessories, a rubber-coated center section to prevent it from sliding down the line, and a reflective strip for increased visibility. The product also complies with 4WD competition damper regulations.
WARN Wireless Control System
Our new wireless control system lets you remotely control your WARN winch from up to 50' away. It simply plugs in where you'd normally attach your corded remote, and on truck and utility winch applications, there is no wiring: just plug it in and you're good to go. (The wiring isn't difficult on the powersports version, however). The weatherproof transmitter has two large buttons making it easy to operate, even while wearing gloves. Two-color LED provides clear operator feedback. Available for truck, powersport, and utility winches.
WARN Neoprene Winch Cover
Keep your WARN winch looking new with these Neoprene winch covers. Made from durable, formfitting Neoprene, these covers provide protection from flying stones, road debris, and the elements. Available for the WARN ZEON, VR, and Tabor truck winches; Series 9, 12, 15, and 18 Electric Industrial winches; and WARN DC1700, DC3700, and DC4700 Utility winches.
PullzAll Sling
The PullzAll Sling is ideal for moving large or bulky items with the WARN PullzAll. Durable nylon construction ensures plenty of durability. Exterior straps allow for numerous rigging configurations. Features a 1,000 lb. capacity, and can be used with any WARN PullzAll.
Source: http://www.warn.com/blog/2013/11/15/new_warn_winching_accessories.shtml
I want that hook!!! Any idea on what cost is going to be?
Google is an amazing thing. ;) http://www.lowrangeoffroad.com/index.php/warn-premium-winch-hook-for-18-000-lbs-8165-kg-capacity-winches-and-under-92091.html
bah I guess your just a better eugoogalizer than me :(
Term: eugoogalizer
Definition: one who speaks at funerals
Forgive me, is Warn the best-of-the-best when it comes to winches? They are pretty damn expensive, but when I buy a winch I want the best. Because dammit,if you need a winch, you NEED a winch, and I'd rather not be wishing I saved myself $200 by buying something inferior.
Damn those are some awesome looking D rings and Winch hooks. I dont have a winch but a couple of those D Rings would look dead sexy on my truck. :)
1 - 12 of 12 Posts
