1 - 20 of 137 Posts
Username: Rushy_Rush
Year: 2005
Trim: SE 4X4
Color: Lightning Silver
- Radflo 2.5" Coilovers 650 lbs Springs w/ 1" Spacer
- Camburg Titan UCAs
- Dirt King Titan Heim Tie Rods
- Bilstein Extended Travel Rear Shocks - Page 2 - 9/8/13
- 1.5" Wheel Spacers on all 4 Wheels
- 2013 Nissan Armada Platinum M205 w/ 3.36 gears - Page 2 - 9/1/13
- 2011 Nissan Xterra Pro-4X M226 w/ 3.36 gears - Page 2 - 9/8/13
- Titan LCA - Page 2 - 9/1/13
- Titan Half Shafts - Page 2 - 9/1/13
- 4 Degree Shims - Page 2 - 9/8/13
- Nisstec Extended front and rear brake lines - Page 2 - 9/1/13
- Energy Suspension 4.5in Bump Stops - Page 5 - 9/22/13
Powertrain/Driveline Mods:
- Volant CAI - 3/8/13
- Magnaflow 2to1 w/ Custom Pipes - 6/1/13
- XTP Blue IMS - 10/12/2014
- Radiator Transmission Cooler Bypass - 7/15/13
- External Transmission Cooler - 7/15/13
Armor & Exterior Mods:
- Front Bumper - Custom Built - Page 12 - 1/1/2016
- Rear Bumper - Custom Built - Page 12 - 1/1/2016
- Sliders - Custom Built - Page 9 - 5/12/15
- Tinted Driver and Passenger Windows - 7/19/14
- Custom Blue Grille
- Plasti Dipped Hood - Page 7 - 11/24/13
- Trimmed Front Fenders - Page 5 - 9/27/13
- Herculined Bottom edges - Page 8 - 7/1/13
- Rustoleum Bedlined Grille - Page 8 - 7/1/13
- Rustoleum Bedlined Side Moulding - Page 8 - 7/1/13
Removed Items:
- **Removed** Calmini Wheel Travel Correction Bracket - Page 9 - 9/15/14 (
- **Removed** Hefty Fab Low Hoop Front Bumper - 8/16/15
- **Removed** Titan Inner & Outer Tie Rods - Page 2 - 9/1/13
- **Removed** Herculined OEM Step Rails - Page 8 - 7/1/13
- **Removed** EBay Titan UCAs with Ball Joint (Garbage Terrible Design)
- **Removed** Hankook Dynapro MT's 285/70/17 - 9/20/13
- **Removed** Daystar Shackles (Nisstec Shackles are longer, Daystar should advertise at 1.5")
- **Removed** Daystar 2" Spacer
- **Removed** TJM Extended Travel Coilovers - Page 2 - 9/1/13 (too soft for T-Swap)
- **Removed** Stock Titan UCAs - Page 2 - 9/1/13 (Coilbucket contact when upgraded to Radflos)
Most Recent 1/2/2016
Fresh Titan Swaped in 2014?
*photo by UnixManDT
Looks like your going to have few busy upcoming weekends ! :iconbiggrin:
Still waiting for TJM Extended Travel Coilovers to get here. Trying to decided if I can afford to buy new leafs before the install or wait till later. Either way Im pumped to start my Titan Swap.
Where in the springs are you located? I have seen a few Silver one's lately, do you have a pic to post?
I live by Black Forest and Woodmen. I will post a pic when I get home tonight. I have think I have actually seen you before, I was headed South on Powers and tried to pull up next to you and wave, may of not seen me, that was about a month or two ago.
Starting my Swap this weekend, provided the bolts show up to attach the Half Axles to the Front Diff. The bolts should arrive at the dealership tomorrow.
Pretty sure my husband saw you then. He mentioned a few months back about anothee X that tried to or did catch up to him and waived. He said silver with TNX.org sticker. You really cant miss us. Dark with black bumpers and a **** load of stickers
Discussion Starter · #13 ·
I would love get on the trails soon, but I will still need new tires after my Titan swap. My current tires, Radial Long Trail, are very very worn down. Hoping to be good to go by the middle to end of September.
Discussion Starter · #14 · (Edited)
Titan Swaped
After 2 Weekends of hard work, 5 days Total, my Titan Swap has been completed. Full log below with Pics.. Took me a fair amount of blow torching & pounding on with a 4lbs hammer to remove the bolt that holds the LCA to the Spindle, bolts came out mangled and smashed. Luckily the dealership had 2 bolts and nuts for a Titan that fit perfectly. Had to do some modifying to the center bolt on the leafs to make them work. Other than those issues with Spindle, LCA, and Center bolt everything installed smoothly. Total lift came to about 3" over stock. The Pre Titan Swap picture has 2" Spacers and Shackles, Spacers were removed for Titan Swap.
Before Swap w/2in Spacers and Shackles
Parts
Front End Jack Up
Front End Being Removed
Installed M205, UCA, LCA, TJM Extended Coilovers, Tie Rods
Stance Improvement
Rear End Jacked Up
Rear End Jacked Up
C200k Yanked Out
C200K Next to M226, M226 is the one on the left.
Shim and Center Bolts
New Rear Shocks
New Shims and AAL Installed
Nice Pinion Angle
New Axle In
Intial Flex directly after Titan Swap
Veteran - AKA Truffle's
Hey Rushy Rush if you want some tires for the rest of the wheeling season for a cheap price pm me, I have some km2s for 17" rims that id be willing to practically give you since your local. They have plenty of tread on them for wheeling. By far my most favorite tire ever. Also when I say give to you, I mean it
Discussion Starter · #20 ·
PM'd You
1 - 20 of 137 Posts
