Status
Not open for further replies.
1 - 12 of 12 Posts
Sold,,,Thank you !
From the garage archives;
Calmini AAL kit:
4 leaves and 2 shims
for 2005 Xterra They came off of mine.
You will have to pick-up new bolts.
$75.00 plus shipping
JimB
Can I call a tentative hour dibs? LoL. I can pick up local too to save you the hassle. I just need to see if I can scrounge up the cash.
Okay ! It's tentative . Yeah pick-up would avoid hassle.
Yes, they will lift the rear about 1 to 1- 1/2"
If you are looking for that Great Lift, give a call to PRG and get PRG's shackles. They have three height adjustments. Mine are set at the lowest setting.
Sorry for the delay. I tried my best but no funds availabe for a bit. I'll contact you later if they are still around. Till then, I withdraw the dib.
Thanks
how much wear do these have on them?
Discussion Starter · #12 ·
less than a year. I have only used the X to and from work and 1 to 2 off-road adventures per month. The calmini is still visible on the leaves and the shims are fine. I still have the original instructions for what they're worth
the trick to this is, you have to get new u-bolts. No gimmick,,, I changed the suspension to the Deavers and PRG shackles and I'm tired of tripping on them in my garage.
Check Calmini, they are $149.95 & shipping from them !
1 - 12 of 12 Posts
Status
