Help me out here ... these have 9 10W LEDs per housing, right? Is that rated output? Nominal consumption?
Either way, seems like some kind of discrepancy ... that's a nominal 90W requirement per housing, but the specs list draw at 5.4A for 12V (64.8W) or 2.5A for 24V (60W) ... there's a factor of 1.5 missing somewhere, and that's not even accounting for any heat generation (which presumes 100% efficiency of light output).
At any rate, these are taunting me ... if it was a set of four, and not just two, they'd probably be gone. Got any more hiding out in your stash? Even a third might just make it too good to pass up for me ...
I think I could scrape up 2 of the 60W (2x3) in SPOT pattern if that would help at all... And of course they would be less expensive for you as there are no shipping charges!
But yes, I agree; there is always something missing when dealing the the chinese I listed the harness above just to be safe.
Well I definitely need these gone... So if it would help "seal the deal" I have 2-3" 2x2 in flood as I have 6 total for my rig, I'm sure I could free up 2...New in box, never installed...
