Status
Not open for further replies.
1 - 8 of 8 Posts
Brand New 30" LED LIGHT BAR AURORA ALO-30- P4E4D comes with light cover.
$426 shipped cash or credit
Full details:
http://www.offroadgorilla.com/30-Dual-Row-LED-Light-Bar-ALO-30-P4E4D.htm
Has combo light pattern outside LEDs are flood pattern center LEDs are spot
Same if not better than Rigid Industries in quality and performance compare the, side by side.
Performance -
The light output of these LED bars is simply phenomenal, they produce a mass of clean white daylight (5000k), free of artefacts and focus dead spots. They light the entire forward viewing area, giving greater visibility without eye fatigue.
Incredible lumen output for current draw, with no warm up time, and can be cycled repeatedly without damage (Ideal for high beam applications)
Features -
IP68 Rating- The highest possible protection rating from ingress of dust and water, run them under water or at the back of a dusty convoy. No problem!
Extruded oversized heatsink. LED's produce heat, managing this heat will ensure long life of the OLSON LED chips and ensure consistent performance for over 50,000 hours ensuring they go the distance.
Included full wiring harness including, relay, switch, fuse and connectors.
Led Light bars are a great option for massive amounts of light up front, if you're looking for a blanket of light from your vehicle forward with great side penetration (hard to get with spotlights) then LED Light bars are the way to go!!
Each LED is 5W and there are 60 LEDs in this bad boy!!
LED QTY & WATTAGE
60 @ 300W, 5W LEDs, COMB pattern.
LUMEN OUTPUT / AMP DRAW
16800 / 12.7A
BEAM DISTANCE
1550Meters
•96% Reflector Efficiency – Less Wasted Light!
•50,000+ Hour Lifespan – Will Not Burn Out!
•GE Lexan Lens – Rugged Lens Will NOT Break!
•Instant On/Off – LEDs Do NOT Require Warm-Up Time
•Operating Temps -40 to 155 deg F – Any Weather!
•Dual, Oversized Heat Sink – Dissipates Heat So LEDs Do NOT Burn Out
•Passes Military Standards – Built For EXTREME Durability
•100% Waterproof – Housing, Connector, EVERYTHING!
^Dude, are you parting out your truck and not telling me? Or did I miss something? What's up?
I wish I had a use for more LEDs...but I don't lol.
Haha no no. These are all parts from when I went nuts and bought everything I could...
Now selling them to fund other mods ;)
1 - 8 of 8 Posts
Status
