Status
Not open for further replies.
1 - 6 of 6 Posts
Complete R180 front differential from a 2007 Off-Road with Manual Transmission
  • Differential removed to swap in a Nissan Titan front diff
  • OEM geared at 3.69:1 ratio
  • Regular fluid changes, no issues
  • Bushings/mounts are in decent shape, axle seals changed ~15k miles ago
3.69:1 OEM Ring and Pinion from the same 2007 m226 Rear Differential w/ E-Locker
  • I had the axle re-geared to 4.56:1 along with front diff swap, this R&P set is what came out
  • Regular fluid changes, no issues, no uneven wear
Would like to sell as a set, would consider splitting. Located in Denver, CO - not really interested in shipping.
Gas Wood Bone Auto part Composite material
Gas Auto part Metal Machine Automotive exterior
Gear Crankset Bicycle part Wood Household hardware
--- Where are you located
1 - 6 of 6 Posts
Status
