1 - 20 of 342 Posts
Username: Snowtrout
Year: 2012
Trim: Pro-4X
Transmission: 6 Speed
Mileage: 90,000 as of 2/24/18
Rig Nickname: Barney
Intro Photo:
Suspension/Tires/Wheels:
PRG/Radflo 2.0 extended length coil overs w/600# springs Rebuilt at 75,000 miles (48,000 on them)
Nisstec 1" top spacers and extended studs
PRG UCA with 1/4" spacer removed and coil buckets filled down Uniballs replaced at 75,500 miles (48,500 on them)
PRG/Deaver AAL
Nisstec/Radflo 2.0 rear shocks
PRG adjustable shackles (middle hole) (Thanks Kd26)
285/75R16 Goodyear Wrangler Duratrac BW
Matching spare wheel(Thanks Kd26)
Hellwig 550 helper springs
Lighting:
Fog light and off-road light rewire
LED interior lights
LED reverse lights
3" Flood pattern LED pods X4 on each corner of the rack
6" Combo pattern LED bar X2 on the rear of the rack
LED license plate light
Sylvania ZXE headlights
Sylvania ZXE fog lights
4 KC Hilights, 2 spot 2 driving
Lower glove box lamp(to be wired in)(Thanks Ramness)
Yakima fat cat 6 (Seasonal)
OEM window visors
Melt mod
Locking wet box handle (Thanks JARunning)
Raingler 3" grab handles
OEM hood deflector
Stealthed front bumper silver (Thanks Jakedublu)
Custom drop in basket(Thanks Craig and Jakedublu)
Horns stealthed and relocated behind the grill
Key-less entry key pad
Xoskel light cage
OEM all weather floor mats
OEM rear cargo cover(Thanks Chase)
GPS docking station(Thanks AZXterra410)
Raingler gate pocket
Raingler seat headrest handle x2
McMaster Carr 9416K28 150# rear hatch struts with 9416k79 ball ends
Rear cargo area cable to hold cover open(Thanks Ramness)
Auto-dimming rear view mirror with compass and temperature(Thanks Ramness)
Electical:
Uniden PRO520XL
Midland 75-820 (Back up unit in rear storage)
FS II 3 ft
Craven Speed Stubby antenna
Gamin NUVI 2497LMT
White Knuckle sliders (Thanks SPZXterra)
Hefty full skid set (Thanks Mudlover55, Xterratsp4 and thanks Jakedublu for painting them)
Ballistic Fab M226 diff cover(Thanks N.Y.X. for setting up the group buy/new product development)
Shrockworks front bumper and radiator skid plate
Boulder Ironworx shock skids
Insain Fab rear tire carrier
Recovery/Trail Gear:
Hi-Lift jack
VIAIR 400p automatic air compressor
ARB tire deflator
Engo E10000S
Smittybilt 7/8" shackles/D-rings X4
ARB trunk protector
Smittybilt snatch block
Engo wireless remote
Smittybilt 3/4" shackle/D-ring X1
Factory 55 Prolink-black
ARB snatch strap
ARB recovery bag
Smittybilt tow strap
Performance/Drivetrain:
Volant #12740 with AEM dry flow filter
Locker anytime mod
Airflow snorkel with volant adapter
XTP IMS
Magnaflow #12580 Dual inlet single outlet
Doug Thourley "B" pipes
Removed Items:
All 6 mud flaps/splash guards- Gave to local member
Stock step rails- Gave to ChrisHaynesUSA
PRO4X carpet floor mats- Gave to a local member
Dealer license plate frames x3 sets- In the garbage
FS II 4ft antenna- Sold to local member
Rear sway bar- In the garbage
Tow hook X2- Gave to two separate local members
Stock cross bars- Gave to a local member for a friend
Stock skids- Gave to local member for services performed
Dash top tray- Sitting in storage
Bilstein 5100 #24-187152 rear shocks- Sold to local member
Stock front suspension and rear shocks- Sold to local member
Stock airbox and intake pipe- Airbox gave to local member, pipe scrapped
Stock diff cover- Sitting in storage
RockyMtnX rear recovery brackets- Sold to a local member
Stock rear bumper- Scrapped
Stock rear hatch stuts- In the garbage
Stock auto-dim rear view with compass- given to local member
Rockymtnx winch mount- sold to local member
Heftyfab radiator skid plate- sold to a local Frontier
Stock OR lights- sold to local member
Replaced Items:
Windshield 9/13/13
Plastic button that contacts the clutch interlock switch for starting 12/27/13
Front bumper cover. Original was damaged due to a rock incident while wheeling 11/1/14(Thanks Travzilla and Surf and Snow)
Parts 62675 and 62050G damaged from above incident 11/8/14
Part # 46310 due to a brake fluid leak 3/2/15
Windshield 1/12/16
Front body mount bushings 8/17
Front sway bar bushings 8/17
Warranty Items:
Parking brake adjustment at 22,500
Discussion Starter #7
Thanks. I know its not the best looking rig out there, but you got to start somewhere.
Looks good bro! Love that action shot. NOW STEALTH THAT BUMPER OUT! :)
That's the plan.
Great start! Clean lookin X. Your planned CB mounting spot is where I mounted mine. Here's how mine looked I really like the location.
One thing you might notice, I don't have as much room behind the CB and the dash. The antenna cable does not fit and I will hit the CB with the shifter in first and possible third. I need to drill the plastic to route the cable through it and get it far enough back for clearance. That's the reason it is still to be installed after having it for three months. Guess I am just lazy.
Looks good
For exaust a lot like magnaflows... I will be getting a flowmaster super 44 but thats just me
also i would recommend a tuner, hypertech or bullydog, and also get a IMS spacer you will not regret it
I have the Flowmaster Super 44 and I love it! Feels punchier at the throttle then the Magnaflow I replaced. I have the tail pipe cut off after the muffler and scooped down but surprisingly it's not that much louder.
Discussion Starter #15 (Edited)
Nice build . I have the same uniden 520xl mounted in the same spot too. I notched the back of the console so it sits back further .
1 - 20 of 342 Posts
