Hi all, I was able to find lots of threads on this, that didn't quite hit the mark.
I have an 06 automatic with 2" lift and 285 tires. I never had a problem with my slip sensors with the lift and oversized tires. I then had my rack and pinion replaced, and the first shop really screwed things up. (Nothing was attached properly) My slip sensors have gone off around every corner above 10mph since.
A reset on the system helped, but was short lived. We replaced the steering angle sensor, with some help. Now the slip sensors stop activating when I apply the brakes in a corner. (They activated every corner no matter what u did previously.)
So now my debate is if I try the system reset and let the truck learn itself again, or do we go to the wheel sensors and replace, since they are linked with ABS from my understanding.
Anyone with similar experience?
