Mosi said:
Okay... so how about just the location of the wiring harness to plug in the tuner??
In the manual this is what it says about the satellite radio antenna & tuner:
SATELLITE RADIO ANTENNA
Removal
1. Lower headlining. Refer to EI-30, "HEADLINING" .
2. Disconnect satellite radio antenna connector.
3. Remove satellite radio antenna nut.
4. Remove satellite radio antenna.
Installation
Installation is in the reverse order of removal.
SATELLITE RADIO TUNER
1. Disconnect battery negative terminal.
2. Disconnect satellite radio tuner connectors.
3. Remove satellite radio tuner screws, and remove satellite radio
tuner.
(There are 4 screws shown in the diagram)
There is also this info:
Satellite Radio Tuner (Pre-wiring)
The satellite radio tuner pre-wiring allows connection of a satellite radio tuner.
Power is supplied at all times
- though 15A fuse [No. 17, located in the fuse block (J/B)]
- to satellite radio tuner pre-wiring terminal 32.
With the ignition switch in the ACC or ON position, power is supplied
- through 10A fuse [No. 4, located in the fuse block (J/B)]
- to satellite radio tuner pre-wiring terminal 36.
Ground is supplied through the case of the satellite radio tuner.
Then audio signals are supplied
- through satellite radio tuner pre-wiring terminals 21, 22, 23 and 24
- to audio unit terminals 41, 42, 43 and 44.
The "Satellite radio tuner (pre-wiring) M41" is located in the area of the lower dash on the left-hand side. M41 is the name of the connector.
