1 - 2 of 2 Posts
This set fits:
The following vehicles without a body lift. If you have a 2" or 3" body lift please order our other VQ40 kit.
05-17 Frontier.
05-15 Xterra
05-12 Pathfinder
09-13 Suzuki Equator
$225 for the complete set shipped to your house.
Click here to order
The above listed vehicles should have the Engine Type: VQ40 - 4.0L V6 This is the standard engine in the USA.
We also carry coolant hoses for: Nissan Titan VK56, Nissan Titan XD Cummins and Nissan 3.3L engines.
High Temp 3-ply Reinforced Silicone Complete Radiator Hose Kit
Our kit is a direct replacement for your rubber OEM hoses. The picture of the black hose set is all of the OEM hoses our set replaces.
Unlike Rubber hoses, our hoses will not crack, stiffen or fail over time. Also our silicone hoses offer a wider operational temperature range than rubber hoses. Our hoses are hand built using a multi-ply method, which enables them to withstand much higher operational pressures, then extruded hoses.
Stainless Steel Worm Clamps Included
Lifetime Manufacture Warranty.
Catch Can Hose Option: Two 3’ x 3/8” ID silicone hoses for a catch can setup. Hoses will color match your coolant hoses. Catch can hose is listed as it own product listing under Cooling.
** Please Note: Your hoses will be made custom made and will take approximately ~4 weeks to be shipped out to you. Special Order Colors can take up to 7 weeks.
Do you know if these will work with he 4x4parts bodylift? It says that I don't require the extended hoses for the install, I just wanted to confirm before I ordered. Going to order tonight.
1 - 2 of 2 Posts
