I'm curious if anyone has used the PRG 3" spacer. Does it cause more, or more harsh contact with the spring bucket?
I realize that if I lift it with spacers, and with out TC UCAs , and Radflos I will have some contact. Just curious if the 3" spacer is noticably worse then a 2 or 2.5" spacer.
Conversly, in the rear to equal a 3" spacer, should I do shackle and AAL? do AALs ride stiffer then the OEM units?
