1 - 10 of 10 Posts
So I have a question, about a week ago my X started squeaking really bad. I believe it is coming from somewhere in the rear but hard to tell. When I take off from stop it goes tic, tic, tic, than squeak squeak squealllllll!! and gets louder as I put a load on. Also when I reach about 60mph it shakes really bad. Has this happened to anyone? Does anyone have any ideas?? Thanks.
I know it's not the breaks, possible U joint and someone told me maybe the carrier bearing? I cannot move the drive shaft and nothing leaking.
I know it's not the brakes:violent1:, possible U joint and someone told me maybe the carrier bearing? I cannot move the drive shaft and nothing leaking.
I'm assuming they mean a driveshaft carrier bearing (not a differential carrier bearing). The Xterra does not have a driveshaft carrier bearing, fyi. It has a single u-joint on the front of the rear DS (the one that you are hearing) and a non-servicable cv joint at the rear of the rear DS. The front DS has 2 u-joints. Because both DS's spin all the time you are moving (regardless of being in 2wd or 4wd), it's recommended to replace all 3 u-joints at the same time. I'd recommend buying some Spicer's from Northern Drivetrain.
I have a 2005 as well (4x4), and mine has been squeaking for ever! I had my breaks changed 3 times within a year's time, so I know it's not the breaks. I was thinking about cleaning out my leaf springs- I read on another thread that gunk can get caught up inside there and cause squeaking.
If it is u-joints, what would it be (roughly) to replace all 3, and is this a job for the dealership? FYI- I'm brand new at vehicle mechanics...but all of my armor mods and stuff I'll be doing myself.
Just called my local dealer, they charge, get this...$400-$500 to replace all the u-joints on an X!
To do it yourself, parts ~$50 dependsing on what u-joints you buy, $60-$70 for tools, $12 for beer and a half days work
U-joints are pretty simple. You would need to by a u-joint tool kit ($60 harbor fraight), new u-joints and a retainer ring pliers.
I think there is a how to on here and if not, a simple you tube serach can help you out.
1. take DS off
2. take off retainer clips
3. press out u-joints
4. press in new joints, being careful not to crush any of the little roller bearings inside!
5. grease joiuts, if you bought greasable ones
6. install DS
It ended up being the u joints, pretty simple to fix. Maybe took and hour or so. Thanks for all the info.
You can rent the tools from auto zone. If you have access to a shop i used an arbor press when i was at school and that made it really easy. I also found a shop that would press em in for like $15 cuz i had the joint and the drive shaft removed already.
1 - 10 of 10 Posts
