1 - 20 of 23 Posts
I am ordering the AAL kit soon to give the rear a little more lift than with just my Calmini shackles alone. I havn't decided which manufacturer to go with yet, but was just curious if I will have to buy new longer shocks and extended brake lines. I have the stock Bilstien's from that came with my X, I have removed my rear sway bar, and I do wheel my xterra. Any help would be much appreciated...
If you keep the stock shocks, they will be the limiting factor and thus saving you from needing extended brake lines.
In Limbo
I got a total lift of about 3.5 inches after the Deaver AAL and PRG Shackles.
The Deaver should give you a lift of 2" - 2.5".
The PRG shackle is adjustable. There are 4 settings.
Here is a photo of the PRG shackle painted red.
so you have four options....so the lhigher the shackle is mounted the more the lift?
On Gregs website the deavers say 1.5' of lift...are the 2-2.5' deavers special order?
Thanks for the help guys...
mcampana said:
I have bigger shocks, deaver aal, prg shackles, and no extended breaklines. Dont need em.
I think I'll go that route.... with the exception of having calmini shackles
Mark, do you have the part number and/or size of the shocks you are now running?
In Limbo
The shocks that Mcampana and I run are Bilstein 5125s. They are long enough to support the PRG rear components lift.
Greg's current website is out of date, so you need to call him to get the current products and prices.
I've got the Calimini Shackles in the back right now, so if I get the Deaver AALs, I should get these shocks as well?
Discussion Starter · #12 ·
Thanks. I'll just call Greg when I'm ready to get the Deaver kit and the shocks.
As long as the correct shocks are used, the brake lines should be fine. Here's a pic of an X with our longer Bilsteins on stands and completly extended. Keep in mind that becasue the lines are between the shocks, they wont get any longer even at max articulation.
Greg,
Thanks for the picture. Looks like the ABS lines AND brakelines will be okay. What is the part no. for those shocks?
(This could be a valuable resource for future reference/searches)
Sooo........will you know during installation if you need them or not? It just sounds scary to think that you could install the lift and then take it for a drive and one day you over extend them and something terrible happens.
Can something terrible even happen? Forgive the lack of knowledge on this subject.
In Limbo
After you install longer shocks you would be able to see if your break lines are being stretched at an unsafe length.
Also, the reason for extending is to allow maximum flex in your suspension. This kind of flex is normally only attained, on purpose, while off road.
As said before, you shouldn't have to extend your break lines. But, if for some reason you have shorter than average lines you will notice after installation.
1 - 20 of 23 Posts
