It's tripped for a reason, not just mileage. The SES light will go away once the problem is fixed. In some cases it needs to be cleared with a scan tool, but they go away on their own for the most part.Hey Guys, I’ve done a forum search on the topic and read loads of good info! I’ll do a scan and go from there.
Question: The X has almost 100K miles, would this cause the SES light and how to reset? Thnx again!![]()
Yes once the condition that caused the code to be set is resolved the computer will clear the code after several cycles. I don't remember how many times the computer has to have the green light (no code conditions) but I want to say after about 6 start and runs the SE light will go off if their is no issues.They go away on their own?🏆
Yes, scanner said MAF sensor. Code P0101…Mine was a MAF sensor warning….
P0101Warning lights are not arbitrary or black magic. They are generally very specific. Get the code read.
Mine had that code and it was just from the airbox lid not being all the way installed under the tab. I would pull the lid and check all ducts and boots for cracks, hose clamps and airbox lid and filter. If there are any air leaks it will throw a code.P0101
Yeah I’ll do some checking before buying a MAF sensor. At 98K miles, I wonder if it’s time to replace anyway, read these sensors are problematic. I guess 22680-7S00A is the updated sensor. And a huge difference in price between OEM and aftermarket. Is there an aftermarket brand that’s good, comparable to OEM? Thnx!Mine had that code and it was just from the airbox lid not being all the way installed under the tab. I would pull the lid and check all ducts and boots for cracks, hose clamps and airbox lid and filter. If there are any air leaks it will throw a code.
Our MAFs aren’t problematic. Just clean it using MAF sensor cleaner and reinstall.Yeah I’ll do some checking before buying a MAF sensor. At 98K miles, I wonder if it’s time to replace anyway, read these sensors are problematic. I guess 22680-7S00A is the updated sensor. And a huge difference in price between OEM and aftermarket. Is there an aftermarket brand that’s good, comparable to OEM? Thnx!
Also I noticed Nissan MAF NOS (22680-7S00) for much less, I assume that’s what’s in the truck now. Any bad experiences using the old stock?
You can try cleaning the MAF, and resintalling it. Incredibly easy, 2 screws and a clip. But take a close look at the air box because I found the airbox wasnt seated properly when the dealer installed a new air filter. MAF cleaner is like 10$. If that doesnt work, a new MAF sensor...and if that doesnt work you can inspect the intake for leaks and just start duct taping the whole thing (kidding).Yes, scanner said MAF sensor. Code P0101
Ok I’ll clean the MAF sensor before ordering an Hitachi replacement. …but please explain your clean process, good to know. Thnx zanethan!Our MAFs aren’t problematic. Just clean it using MAF sensor cleaner and reinstall.
It worked (for now : ), SES light is off!I found a good step by step video to clean the MAF sensor!
