1 - 3 of 3 Posts
the X is not listed on the supported list, but follow these directions to see if it will still work...
from the dashawk website....
"If you vehicle is not listed in the supported vehicles page, all is not lost! There are many vehicles being added/tested every day and it is hard to capture them all and keep them up to date, so a good way to see if your car has a CAN bus is the following:
Locate the OBDII connector. It is under the dash on the driver’s side of the vehicle, often either under the steering wheel or tucked up next to the driver’s side kick panel.
Look carefully at the plug with a flash light or other bright light source. If pins 6 and 14 have metal pins in them (i.e. are “populated�) then the vehicle has a CAN bus and DashHawk will most likely work with this vehicle."
http://www.dashhawk.com/faq.html
1 - 3 of 3 Posts
