1 - 20 of 349 Posts
Ordering parts this week, and hopefully start the swap in two-three weeks. Will keep everyone updated if interested.
Part's List:
Dana 44 - Ford Bronco 78-79
Dana 44 4.56:1 Ring and Pinion
Dana 44 Master Install Kit
Ford 9" - Ford Bronco 78-79
Ford 9" 4.56:1 Ring and Pinion
Ford 9" Master Install Kit
Bronco Monster Radius Arms - High Travel
Fox 2" Coilovers - Emulsion
Eibach 300lb Coil Springs
Rebuilt Steering Box
Custom Tie Rod and Drag Link
Pittman Arm
Ford Radius Arm Clamps
Custom Front Track Bar
Steering Shaft
Bilistien Shocks - Rear
Misc Front Axle Parts - Brakes, Brake Lines, etc.
Custom Hydraulic Steering Lines
Custom Front Bump Stops
Custom HD CV Drive Shaft
Custom T-Case/Tranny Mount/ Skid
Misc Parts for Rear Spring Over
Custom Front Skid Plate
EDIT: Adding pics on the first page since most links in the thread are dead.
damn, your not wasting any time..that is badass...
Definately keep us posted and post lots of pics!
Re: SAS is a go!
Offroad said:
:eek:ccasion5: :thumbright: :thumbleft: :hello1:
Please...
About the rear SOA, will you have to move the axle forward and/or modify the driveline angle
It will need a new drive shaft for the rear, but we don't expect to move the axle. I will let you know for sure when we are working on the SOA.
Crap there goes next years tax return!
Good luck and keep up very updated with pictures if you could. Something else that would be cool is a daily log, or journal, that you could post. This would show people how much work it is, and what are typical problems on this type of swap. It is just a thought.
Dude if this works you better take pics and a very detailed write up during the whole process. If not then you're banned from here. J/K. :D Keep us all updated.
all that work so he can put black steely's on. :laughing4: :nike:
Discussion Starter · #12 ·
What a day, just got back from the junkyard. Im a proud owner of a dana 44 ford 79 bronco axle! Thanks to some nissan owners, we got it pulled off today, and got a sweet deal. And we also found out the X should be able to run 15 inch wheels now.
Discussion Starter · #15 ·
dynamix said:
i know its early, but have you figured out if you will be running 35s or maybe even bigger tires? thoughts on that?
I will be running 35s. I was aiming for 36-37 inch, but the rear axle can't be regeared until Nismo comes out with something. So since im staying with stock gears, I will stay at 35s.
Discussion Starter · #16 ·
Well I stopped being lazy and started updating my Alpine X site. I will post here and update my site during the process. My Alpine Tribe Site
Great. I'm waiting anxiously you for you to get the install done. If it works out then I'm going to get myself a donor axle and start working on getting the needed parts. :D
G
Jordan, what is the approximate cost of the parts so far, and what is the projected total cost of the project at this point? ( with separate costs for parts and labor if you are paying Allphase for the install. )
1 - 20 of 349 Posts
