Username: Santims
Year: 2007
Trim: SE
Color: Night Armor
Nickname: The Bomber - Given to me by my wife...my darn license plate starts B52...get it?
Tires:
General Grabber AT2 265/65R17
I really need 33's.
Suspension/Lift Mods:
2" Spacer front lift (Top Gun Customz)(Installed 5/29/12)
2" Deaver AAL (PRG) (Installed 8/21/12)
Shims (PRG)(Installed 8/19/12)
2" Body Lift (AC) (Installed 10/7/2012)
SPC UCAs
Hefty Radiator Skid
Shrock Skids
White Knuckle Sliders (Installed 10/10/14)
South Co Locking Handle (Installed 2/20/12)
Vent Visors
4 additional tie downs in trunk
Yakima Double Down 4 hitch mount bike rack (Does that even count as a mod?)
Rad Bypass
Recovery:
48" Hi-Lift Extreme mounted under rear seat
Hi-Lift Off Road Base
Hi-Lift Lift Mate
Hi-Lift Off Road Kit
Future mods:
Cam Bolts (Waiting to Install & Seized to LCA)
Radflo 2.0 Extended Travel Coilovers
Nisstec Adjustable Shackle
Billstein 2-4" Rear Shock
RockyMtnX Factory Bumper Winch Mount
Comments:
Purchased in 2010 with 28,000 miles. Have been pretty happy with it and have so far needed to fix an AC leak and replace a front hub/bearing. This truck is basically new to me and I have very little time to work on it, go wheeling, or anything else really.
I just hit 70,000 miles and she is still running strong. I have done some minor maintenance and fixed a few small things here and there but everything has been great over the years. Finally starting to get some stuff done recently. Did my first oil change in about 10 years today (2/20/12)
As of 10/7/12:
Just brought it home:
Today:
Chipmunk Mod:
Trunk Tie Downs:
Used a D-Ring purchased from Lowes. For each tie down: 4 large washers (i suggest the largest diameter that will fit in the channel), 2 small washers (if the center hole for your bolt is too large so your bolt does not fit through washers), 2 medium sized washers for above the channel, 2 nylon lock nuts.
When tightened the tie downs will clamp to the metal channel. They do not rattle but next time I would bedline or plastidip them.
As she sits 8/21/12:
First offroading trip 8/25/12:
Year: 2007
Trim: SE
Color: Night Armor
Tires:
I really need 33's.
SPC UCAs
Hefty Radiator Skid
Shrock Skids
Vent Visors
Rad Bypass
Recovery:
Hi-Lift Lift Mate
Future mods:
Comments:
As of 10/7/12:
Today:
Chipmunk Mod:
Trunk Tie Downs:
