1 - 13 of 13 Posts
Hello all,
So I noticed a weird issue today, wanted to check with the experts (e.g: you all) to see what you think.
When I was driving on the turnpike today, I noticed my RPM's get a little jumpy (up and down) only when I am around 1.2k to 1.5k RPM and I am not accelerating anymore.
The truck is an 06 Xterra S, with about 72k miles on it. I do an oil change (full synth) every 3k miles, and my last tune up (engine flush, tranny flush, radiator flush, spark plugs, PVC) was done at 55k about a year ago. I don't know when the distribution caps were changed, but I am leaning towards thinking this might be the issue.
Oh, and it only happens sometimes.. not always.
The RPM's are stable when idle, and when accelerating they are fine also. I don't feel any tranny slipping and I don't hear any grinding / unhappiness from my tranny (at least to my untrained ear).
Thanks again all. Forgive me for the stupid question, I am still learning the mechanics overall :)
how much of a jump, it could just be the transmission downshifting as you slow down, mine does this too and it seems normal - but its never an aggressive downshift you wouldn't notice it if you were not looking at the tach.
our trucks do not have a distributor cap. they do have plug coils on each plug. with that said, what you are describing sounds normal. mine has done it since new and i now have 111,000 miles on her.
i have noticed that it downshifts into lower gear more than it used to BUT that's probably because i am visiting the steep mountains more than i used to. for example, when heading down a steep hill at 60 and if i hit the brake good, it will downshift into 3rd and stay there until i hit the gas again. it did this when new coming down mt mitchell and i thought there was an issue but it's the transmission's way of slowing you down, which i like.
back to your issue, my tach hops up then comes back down when decelerating alot and i chalk it up to normal....
Sounds normal, but it can be excessive (which was caused be me). I had to do an idle relearn at one point after some tuning and a Volant, but that got things back to normal.
Its weird, it will drop and then go slightly back up. The only reason I noticed it originally was I felt the truck jerking (but it could have been the uneven pavement of the NJ Turnpike) but once I hit the OD switch on / off it stopped.
It happened a few other times, but it felt smooth either way.
The idle relearn sounds like it might be the case. I did just throw a Volant in there and lift it up...
I am getting the same thing these days, well after overheating my tranny a few times towing specifically. While I would agree its generally normal it appears to be a little more noticeable now. Changing my trans fluid this weekend, we'll see how it is afterwards. 06 with 99,000 also with a Volant but that's been on there for almost 90k.
Sorry for the resurrect. I have a similar problem and because I'm not used to automatics I'm not sure if it's normal. Everything seems to shift fine when accelerating but if I quickly take my foot off the pedal and while coasting the rpms drop low immediately (below 1000) and then a second later bump back up to normal 1200 or so. It just seemed kinda jumpy in general whenever I'm decelerating or coasting no matter the speed. I couldn't tell you if this had just started or was always like this. I can't even tell if it's a engine or transmission thing.
I had just reset the codes yesterday, would that cause the computer to maybe be relearning?
My other thought was I need to replace the cat converter and maybe backpressure is causing the rpms to drop further than the computer is expecting and so it has to correct?
I also blasted the MAF sensor with MAF cleaner.
2005 SE 4x4.
Mine does the same. When I let off the gas completely at lowish speeds it quickly drops from 1200 rpm to 750 and then back up.
Having a similar issue after changing the spark plugs. When I start slowing down -
regardless of decline or flat road - my engine makes a few revving pulses before I fully stop.
Of note, I'm getting a po420 code, so my catalytic converters need replacing (180k miles now). Maybe that'll fix it.
If anything, it could be the spring inside the torque converter, the one that sets the stall speed, that may be getting worn. My X does this as well...new symptom, but perhaps I just never noticed. I don't plan on doing anything to correct it or explore it any further.
1 - 13 of 13 Posts
