My 06 Off-Road X came with the factory installed Block Heater cable, however, the bulk of the cable was in a zip-tie bundle between the battery and fender. In other words, the "end you plug in" wasn't "installed".
Can someone who either has access to a service manual or who has the Block Heater completely installed by the factory post a description or pictures of the correct locations to route the Block Heater cable. The wiring loom that the cable is wrapped in has a few plastic clips that are obviously intended to pop into some holes to hold the cable in place.
