Nissan Xterra roof rack parts - complete set - as is. Came off a 2015 Pro4X. Available custom built mounting hardware for Yakima Load Warrior and ARB awning.
Overall good condition. Both lights work. Cargo basket still operates properly. Had to 'melt out' many of the bolt holes to remove rack from vehicle because rivnuts were spinning. Should be able to re-use bolt holes when you use washers to cover the hole. Saved 95% of hardware.
Prefer to sell everything together. Will part out if need be.
Will remove u-bolts on main rails unless you want to keep them. Used them for a custom built roof rack mounting bracket system for a Yakima Load Warrior Cargo Basket and an ARB Awning mounting bracket. Happy to negotiate inclusion.
I upgraded to an after-market roof rack system, no longer need these parts.
Message me for any other details. Pick up in Canmore, AB. No shipping. Delivery possible depending on location.
www.facebook.com
www.kijiji.ca
Log into Facebook
Log into Facebook to start sharing and connecting with your friends, family, and people you know.
Nissan Xterra Roof rack parts | Other Parts & Accessories | Banff / Canmore | Kijiji
Nissan Xterra roof rack parts - complete set - as is. Came off a 2015 Pro4X. Will fit most second Gen Xterra's. Available custom built mounting hardware for Yakima Load Warrior and ARB awning. Overall good condition. Both lights work. Cargo basket still operates properly. Had to 'melt out' many...
